VXC 6215, where can I see what firmware ver is running?
ciroizarra
Hi all,
In order to set up a demo, I need to know which RDP version is supported, but that depends on the 6215 firmware (8.6 or 8.7) right?
where can I verify that?
all I've found looking around in the system is
OS 2.6.32.36-0.5-pae
Build 11.1.044
SLETC: 1.4.1115
BIOS 0.3A
I'm having difficulty finding out from the release notes.
Any help would be appreciated!
Thank you!
lpratt
The Build number, which you have above as 11.1.044, indicates what version of code you are on.  That is a very old image.  The first thing I would do is to upgrade to the latest FCS'd image on cisco.com.
Louis
