ā04-17-2016 03:56 AM - edited ā03-13-2019 09:26 PM
Dear experts,
We have two FAX machines manage by Right Fax software,we also have 1 Cisco ATA 190 which we want to utilise
we want to connect our two FAX lines to ATA 190 and integrate with CUCM
first of all i want to know the benefits of integrating FAX machines with CUCM using ATA 190 and the configuration how to do it?
Thanks for your kind support.
Awad
ā04-17-2016 01:34 PM
FAX'es are horrible to deal with in a VoIP environment. They often cause issues.
If you don't need to migrate them to CUCM I would leave them on their current analogue lines.
ā04-17-2016 11:14 PM
is there any third party solution for this ? i.e, making the FAX digital but without integrating with CUCM which is more stable?
ā04-18-2016 08:29 AM
No. They all are just as bad as each other.
