11-23-2002 07:46 AM - edited 03-12-2019 09:42 PM
Hi :)
I have 2 iconnecthere accounts one for inbound/outboound calls & one for outbound calls. I am living in greece and i bought my ata from a local cisco distributor,it came with bootload image & THANK GOD i upgraded through deltathree server by the phone & this way i saw the "sip" entries. It did work well and i was very satisfied when it was connected on my UNI's network,now i moved it to my house after setting up a wireless link -now the net connectivity is slower. I am experiencing problems concerning voice quality, i tried to change the codecs but the results aint so satisfactory. As I did so many changes in all the fields,now i am a bit lost concerning the whole set of settings through the web interface. So can someone tell me,who is in the same situation as i am, what is the best combo of these settings?
My Ata has the following info:
ata000ab7447db0
Version: v2.15 ata186 (Build 020723a)
MAC: 0.10.183.68.125.176
SerialNumber: INM0636D1FS
ProductId: ATA186I2
Features: 0x00000000
HardwareVersion: 0x0005 0x0000
Thank U in advance for any help
Vassilis
ps1: I can supply a snapshot of my ATA configuration page.
ps2: Is it possible to have some assistance from Mr Yarps from Deltathree? (OF COURSE I DONT WANT TO DISTURB NOBODY BUT I A BIT LOST :( )
12-02-2002 11:48 AM
Vassilis, these FAQs will help you solve your configuration settings:
Cisco ATA 186 FAQ and Common Issues
http://www.cisco.com/warp/public/788/voip/ata-faq.shtml
Cisco ATA 186 Basic Configuration
http://www.cisco.com/warp/public/788/voip/ata_basicconfig.html
Configuring and Troubleshooting an ATA 186 with Cisco IOS Gatekeepers
http://www.cisco.com/warp/public/788/voip/ata_gatekeeper.html
Configuring and Troubleshooting an ATA 186 with a Cisco IOS Gateway
12-02-2002 04:19 PM
Thank U for ur help , I ll study these urls.
I have 2 question to ask.
a. When i am pinging my ata i see a ping response aprox 60-65 ms is it normal?. I am asking this cause when i am pinging a pc at same lan and the
ping response is 1-2 ms.
b. As my ata is connected through a wireless lan,its connectivity aint so stable. What is the minimum bandwith requirments ? & what are the less consuming bandwith audio-codecs ?
PS: i am using sip as i use my ata as an iconnecthere subscriber.
Vassilis
12-12-2002 09:54 PM
Vassilis hi,
I will be happy to assist you,
First step have you tried the FAQ section under the customer support, key word ATA ?
If this doesn't help please feel free sending me the current configuration screen and your environment description
Yaron Raps
