10-05-2008 01:08 AM - edited 03-15-2019 05:03 AM
Dear Networkers,
Can anyone help me if we can use any non Cisco Wireless IP-Phone with Cisco Call Manager 5.3 and POE Cisco Access Point ?
Since we have a security issue in our country and we cannot use the cisco IP-Phone,
Thanks all
10-06-2008 05:08 AM
Good morning :)
There *should* be no problems with this, as long as the devices you want to add are SCCP capable or IETF RFC 3261-compliant devices (SIP).
Of course, you will want to check to see if the device you want to install has been previously tested for compatibility. For SIP devices, please make sure to check if the phone has been tested and certified to work with CCM:
VoIP Testing and Certification
http://www.tekvizionlabs.com/3rdpartyprograms/sip_verification/verified_products.php
Hope this helps!
10-22-2008 12:10 AM
At a customer, who's running CUCM v5.1, I've installed Spectralink i640 wireless IP Phones to connect via a Cisco wireless controller WLC4402 and it worked. The IP Phones just talk SCCP. Check out this doc: http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806d11cb.shtml
Greets,
David
