2 N7K, 4 N5K, 8 N2K - double sided VPC
Sonugnair_2
Hello All,
I have a clarification with respect to double sided VPC.
Following are the details:-
1) Nexus 7K - 2 numbers
2) Nexus 5K - 4 numbers
3) Nexus 2K - 8 numbers
The 2K will be connected to 5Ks and 5Ks to the 7Ks. We plan to use double sided VPC and enhanced VPC design. The NXOS on the 5Ks are 5.3(1)N2.
Now in case of two N7Ks and two N5Ks, there is documented case for double sided VPC configuration i.e. the same portchannel everywhere between N7Ks and N5Ks
N7K1 --->N5K1
N7K1---->N5K2
N7K2 --->N5K1
N7K2---->N5K2
i.e
interface <int>
  channel-group 11 mode active
interface po 11
  switchport
  switchport mode trunk
  switchport trunk allowed vlan a,b,c
  vpc11
In our case, in addition to the below
N7K1 --->N5K1
N7K1---->N5K2
N7K2 --->N5K1
N7K2---->N5K2
we also have
N7K1---->N5K3
N7K1---->N5K4
and
N7K2---->N5K3
N7K2---->N5K4
So in this scenario can we use the port channel template that was shown above? Or in other words the double sided VPC design that was valid for two N7Ks and two N5Ks, can it be valid/extended for lets say total of four(or 'n' number) of N5Ks.
I hope the question is clear.
Thanks in advace.
Sorry for the confusion, let me clarify it a bit more:
N7K1 & 2 <-> N5K1 & 2 - Po11, vpc 11
N7K1 & 2 <-> N5K3 & 4 - Po12, vpc 12
N7K1 & 2 vpc domain 1 (let's say)
N5K1 & 2 vpc domain 2
N5K3 & 4 vpc domain 3
HTH,
jerry
Jerry Ye
Except you need to use a different vpc number. For example, N7K1/2 <-> N5K1/2 will be vpc11. N7K1/2 <-> N7K3/4 will be vpc 12.
HTH,
jerry
Thank you for the reply. So:-
N7K1 --->N5K1 VPC 11
N7K1---->N5K2 VPC 11
N7K2 --->N5K1 VPC 11
N7K2---->N5K2 VPC 11
N7K1---->N5K3 VPC 12
N7K1---->N5K4 VPC 12
N7K2---->N5K3 VPC 12
N7K2---->N5K4 VPC 12
N7K Domain ID 1
N5K Domain ID 2
ALL portchannels will be as lets say Po10..
Is the above correct?
Regards!!
HTH,
jerry
Thanks a lot
