in apic controller, pod1(one line below topology), i want to add one spine switch, but if I go to right hand side, operational/switchws/spine, there is no add button, so how to add a new spine? thanks
Hi ,
In the APIC GUI, click on the Fabric tab and then the Inventory sub-menu. On the left hand side, click on Fabric Membership. If all is well, you should see a all nodes listed in here.
In order to register the node and add it to the network, you simply need to assign a node ID and node name by double clicking on those fields.
Now question will come how do we discover the rest of our network? Well, once you have registered the first node, you should magically start to see additional switches (spine nodes) pop up on the Fabric Membership page. Go ahead and register these in the same way.
Hope it Helps..
-GI
