ASAv migration procedure - HA Setup
aconticisco
Level 2
Level 2
What is the recommended process to migrate an ASAv from one host to another but using local storage?
Do I need to disable failover or even shutdown the VM?
Is there any different recommendation based if the ASAv is the primary or standby?
From what I read I see that if I attempt a migration in above scenario I would get an error but cannot find any further recommendation on best practice approach
vMotion Guidelines
https://www.cisco.com/c/en/us/td/docs/security/asa/asa99/asav/quick-start/asav-quick/asav-vmware.html
0 Replies 0
