06-01-2017 08:47 AM - edited 03-01-2019 08:34 AM
We have a C240M4S server after upgrading the CIMC of the server,We installed FreeNAS in it, But while loading the system. it goes to KDB:Enter panic mode.
Can someone help us out ?
06-01-2017 07:34 PM
Greetings.
I am inclined to think that is an issue with the OS/kernel.
You can run the hardware diags (mount the ISO via KVM virtual media) https://software.cisco.com/download/release.html?mdfid=286281356&softwareid=286123307&release=5.0(3a)&relind=AVAILABLE&rellifecycle=&reltype=latest
I'm not sure what procs you have (i.e. V3, V4), but I would confirm your FreeNAS supports the Procs and chipsets, along with storage controller, etc.
FreeNAS is not a tested or supported OS on UCS hardware, so you won't find much reference to it on the Cisco forums.
I would suggest posting on the FreeNAS forums for support for FreeNAS.
Kirk...
06-01-2017 08:26 PM
Thanks for the details. Will give a try now. However i have raised a RMA request for this. Let's see how it goes through.
06-04-2017 08:06 AM
