01-21-2015 12:44 PM - edited 03-01-2019 07:46 AM
Hey guys, I'm starting my journey in the Data Center field. I want to see if it's required to take the CCNA tests because I heard that some CCNP Data Center tests will cover the CCNA Data Center certification. I'm currently a CCNP R&S. I also want to ask if by taking a CCNP Data Center test would renew my CCNP R&S. Thanks in advance.
Solved! Go to Solution.
01-22-2015 08:11 AM
Sleiman,
Yes you are understanding is correct.
A) to Complete CCNP you need to complete 4 papers in total.
Now you have the following options:-
=> 1st two papers are compulsory
=> For 2nd two papers you have options to select:
642-998, 642-996 OR
642-035, 642-980
ref:
http://www.cisco.com/web/learning/certifications/professional/ccnp_datacenter/index.html#~Exam
Inayath
01-21-2015 09:31 PM
Sleiman,
Glad to hear your interest in the field of Data Center field. Here is the answer for your query:-
1- You can do the CCNP Data center without having to do the CCNA data center.
2- Yes CCNP data Center certification would renew your other CCNP.
Cisco Professional-level certifications (CCNP, CCNP Wireless, CCDP, CCSP, CCNP Security, CCNP Voice, CCIP, CCNP Service Provider, CCNP Service Provider Operations, and CCNP Data Center) are valid for three years. To recertify, pass ONE of the following before the certification expiration date:
Hope this helps.
Inayath
***Plz dont forget to rate if this info is helpfull.
01-22-2015 06:55 AM
Great thanks for your response. Now for CCNP Data Center I'm seeing 642-999, 642-997 AND 642-998, 642-996 OR 642-035, 642-980. Does that mean that the first 2 are required and I can select either 2 of the rest?
01-22-2015 08:11 AM
Sleiman,
642-998, 642-996 OR
642-035, 642-980
ref:
Inayath
01-22-2015 09:17 AM
Great thanks so much.
