07-13-2015 01:02 AM - edited 03-01-2019 07:57 AM
hi all
i've a dude with this command:
show mls cef maximum-routes
When i show this command ¡, it's necessity save the running conf, for write new values Size on FIB - TCAM tables ??????
regards
Santiago
Solved! Go to Solution.
07-13-2015 01:07 AM
If you adjust the maximum routes you must save and reload not when you issue show command
After you adjust the maximum-routes, you must save the running configuration and reboot the switch before the changes become active (there is no operational impact before the reboot). After the reboot, you can enter the show mls cef maximum-routes command in order to view the new TCAM allocation
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/117712-problemsolution-cat6500-00.html
07-13-2015 01:07 AM
07-13-2015 01:25 AM
best regards Mark most usefull :-)
