Cisco Hyperflex.
haitham.jneid
Hi All,
kindly need your urgent support regarding Hyperflex deployement.
I have the following hyperflex design:
- 2x6296 FI
- 3x HX220C M4
I will be using the following firmware.
Hyperflex: 1.8(1f)
HX Data Platform Installer: 1.8(1f)
UCS FI: 3.1(2C)
Esxi: 6.0
Vcenter: 6.0
Vsphere: 6.0
from where I can get the Esxi, Vcenter, and Vsphere? from Vmware or from Cisco??
what is the procedure(step by step) to deploy and run hyperflex.?
thanks,
Haitham Jneid
Ignacio Orozco
ESXi comes pre-installed on the HX converged nodes. UCS firmware, HX installer, HX upgrade files, ESXi upgrade zip files and lastly ESXi ISO for server imaging are located here: https://software.cisco.com/download/release.html?mdfid=286305544&softwareid=286305994&release=2.1(1b)&relind=AVAILABLE&rellifecycle=&reltype=latest
You will need to download vCenter from VMware directly.
jkilleda
Level 3
Level 3
Hello Haitham,
Cisco Hyperflex
Please refer to the link given below , it is a complete guide on how to deploy Vcenter on HX platform.
https://www.cisco.com/c/en/us/td/docs/hyperconverged_systems/HyperFlex_HX_DataPlatformSoftware/TechNotes/Nested_vcenter_on_hyperflex.html
