Cisco Nexus 5548P upgrade from 5.x to 7.x
Roger B
Dear Team,
I am using Cisco 5548P and is running with image 5.0(2)N2(1) and now we need to upgrade it to 7.0(4)N1(1). We are ready for disruptive upgrade.
Post uploading 7.0(4)N1(1) image in device it has given additional information message as "LACP: Upgrade will be disruptive as 0 switch ports and 28 fex ports are not upgrade ready!!"
Need to understand upgrade impact on switch/FEX.
SWITCH1# sh install all impact kickstart bootflash:n5000-uk9-kickstart.7.0.4.N1.1.bin system bootflash:n5000-uk9.7.0.4.N1.1.bin
Verifying image bootflash:/n5000-uk9-kickstart.7.0.4.N1.1.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.7.0.4.N1.1.bin for boot variable "system".
Verifying image type.
[###########         ]  50%
Extracting "system" version from image bootflash:/n5000-uk9.7.0.4.N1.1.bin.
Extracting "kickstart" version from image bootflash:/n5000-uk9-kickstart.7.0.4.N1.1.bin.
Extracting "bios" version from image bootflash:/n5000-uk9.7.0.4.N1.1.bin.
Extracting "fexth" version from image bootflash:/n5000-uk9.7.0.4.N1.1.bin.
Performing module support checks.
Notifying services about system upgrade.
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     1       yes      disruptive         reset  Incompatible image
   101       yes      disruptive         reset  Incompatible image
   102       yes      disruptive         reset  Incompatible image
   103       yes      disruptive         reset  Incompatible image
Images will be upgraded according to following table:
Module       Image         Running-Version             New-Version  Upg-Required
     1      system             5.0(2)N2(1)             7.0(4)N1(1)           yes
     1   kickstart             5.0(2)N2(1)             7.0(4)N1(1)           yes
     1        bios      v1.8.0(10/06/2010)      v3.6.0(05/09/2012)           yes
   101       fexth             5.0(2)N2(1)             7.0(4)N1(1)           yes
   102       fexth             5.0(2)N2(1)             7.0(4)N1(1)           yes
   103       fexth             5.0(2)N2(1)             7.0(4)N1(1)           yes
     1   power-seq                    v3.0                    v5.0           yes
     1          uC               v1.0.0.14               v1.0.0.14            no
Additional info for this installation:
Switch is having three FEX's connected to it.
ahmed.gadi
Have you managed to upgrade directly from 5.0(2)N2(1)  to 7.0(4)N1(1) ?
As per cisco documentation you should follow intermediate upgrade.
We are also planning to upgrade from 5.0(3)N2(2) to 7.0(6)N1(1).
If you see the compatibility check results, it says incompatible image.
Hi Ahmed,
I would plan to go to 7.0.7 release as it has a few more critical bug fixes.
Check table 6 @ the link below for Supported Upgrade and Downgrade Paths
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5500/sw/release/notes/7x/Nexus5500_Release_Notes_7x.html#pgfId-584371
-Raj
