'Command Parsing Failed'
cex_teleco
we have 2 Nexus 5K (cisco Nexus5548 Chassis - System version: 5.1(3)N2(1)).
When we are trying to add new vlans to a Portchannel using switch-profile we get this message:
Error(s):
Following commands failed parsing: If the error is 'Command Parsing Failed', please check if some conditional feature(s) needs to be
enabled
switchport trunk allowed vlan 12, 14-15, 17-20, 24-27, 41, 45, 47-48, 50-51, 53-54, 56, 60, 64, 69-72, 75, 79, 82, 84-87, 89-91, 97,
99-100, 103-106, 108, 111-119, 121-122, 124-126, 138-142, 144-152, 173, 183, 188-190, 195, 197-198, 202-205, 207, 210-211, (Command
Parsing Failed)
Checking this document http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/troubleshooting/guide/n5K_trouble.pdf
(page 153), the solution is not specified. Which feature we have to enable?
Now, or features enbaled are:
Feature Name          Instance  State
fex                   1         enabled
interface-vlan        1         enabled
lacp                  1         enabled
lldp                  1         enabled
sshServer             1         enabled
telnetServer          1         enabled
udld                  1         enabled
vpc                   1         enabled
Regards.
pille1234
Level 3
Level 3
it's a known bug: CSCua74057
As long as you don't work with Config sync it is a cosmetic bug only
pille1234
Level 3
Level 3
We are using config-sync and running into this BUG alot.
Does anyone knows if this BUG is fixed in Versions after 7.1(4)N1
I looked through the BUG Search tool but could not find anything.
kind regards
Tobias
