05-20-2016 12:14 PM - edited 03-01-2019 08:16 AM
I have two 3750's that I have to configure as dumb/dirty switches in stack before they go into deployment.
Regarding the same, I had few things that I wanted to clarify.
1. Now I know the switch with lowest MAC Address becomes the master and the other one becomes the slave in a stack. However, my question is do I just configure the master switch and stack it with the slave switch (both have been factory reset before configuration) or do I have to configure both the switches individually and then stack them together?
2. Using the following configuration on the master switch:
enable
write erase
reload
[after switch reboots]
enable
configure [terminal]
vtp mode transparent
no cdp run
interface [selected all the range of interfaces]
switchport mode access
switchport access vlan 1
line vty 0 15
transport input none
exit
exit
write mem
Please advice/suggest anything else that can be added to configure the switch as dirty/dumb switch successfully.
S
Solved! Go to Solution.
05-20-2016 12:54 PM
You can actually define what switch you want as master and "provision" the second switch into the stack.
Pick a switch and configure it like you did above but add the following:
conf t
switch 1 priority 15
switch 2 provision ? (enter the output of the model of switch 2)
int range [selected all the range of interfaces for switch 2]
no shut
do copy run start
Plug 2nd switch into power assuming the stack cable is plugged in it will boot up, be the slave switch with priority of 1, and have the ports you specified in the range command above configured as access port in vlan 1.
What I would also do is after the 2nd switch comes up issue teh below command:
switch 2 priority 10
do copy run start
You can also very the stack by issuing " show switch"
Please rate useful posts and mark answers as correct if applicable.
05-20-2016 12:54 PM
conf t
no shut
do copy run start
do copy run start
