configure DNS for ACI inb and oob
Ido1
When configuring DNS policy for ACI, you can choose whether to use the default profile or create a custom one. Creating and using a custom DNS Profile will not apply DNS Profile configuration to the APICs. If you want your APICs to have DNS configuration you must use the default DNS Profile. Moreover, when configuring DNS policy, you have to specify the management epg (out-of-band or inband).
I would like to know if it is possible to create dns profiles for both inband and oob, and both of them will be apply (not only the default profile).
jiarchen
You can check the guide below for DNS profile configuration. Default DNS profile is suggested to use and assume that not able to create dns profile for both inb and oob.
https://www.cisco.com/c/en/us/td/docs/dcn/aci/apic/6x/basic-configuration/cisco-apic-basic-configuration-guide-60x/provisioning-core-aci-fabric-services-60x.html#concept_2E29EEFB4D734457B9C64284A8EA0984
If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
You can also learn more about Cisco ACI through our live Ask the Experts (ATXs) session. Check out the ATXs Resources [https://community.cisco.com/t5/data-center-and-cloud-knowledge/cisco-aci-ask-the-experts-resources/ta-p/4394491] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
