Copying Kickstarter and Bootfile to N5548 error
SpaceAceFrehley
I'm trying to get these two files onto a N5K. I can successfully boot the kickstarter from our workspace server using TFTP, but once it has booted, the unit seems to not accept any form of transfer.
Copying from USB:
dir slot0:
Usage for slot0: filesystem
 90677248 used
328753152 free
419430400 total
Copying from TFTP (adjusted in loader to necessary variables, confirmed in configure terminal)
copy tftp://x.x.x.x/n500.x.x.x.bin bootflash: " "
Trying to connect to tftp server...
Connection to server Established. Copying started.....
TFPT get operation failed:Network is unreachable
switch(boot)#
I'm unsure what the error could be.
TiA
12 Replies 12
balaji.bandi
Once its booted from TFTP,  are you still have network IP configuration and you able to ping TFTP Server  ?
what is the Logs you see on the device and TFTP server (do you see request established for copy ?)
what is the outcome of  show ip
Quick fix is get copied to USB and boot from USB and Copy from USB quick win here, if that works for you.
BB
As mentioned, USB is not recognised, even after formatting; I am using a known-good USB for the system but receiving no feedback, only the output shown in my first comment:
"dir slot0:
 90677248 used
328753152 free
419430400 total"
I am not finding a ping command in the privilege levels I've tried, but I've retained the same config from the loader on there. "show ip" prints:
ip routing is enabled
ip address x.x.x.x/16
ip default-gateway x.x.x.x
When interfacing with the management port, I receive the following message when attempting to configure the default gateway to the same one I used pre-boot (just to check it has retained the address from before):
"Failed to configure the default gateway".
I can print logs if you know which commands will relay necessary info.
Thanks!
what format that USB - Fat 32 still works ? is this new USB
dir usb1: - should give the information.
BB
The USB is currently NTFS, but have tried with FAT32 and encounter the same message.
I can only perform dir;
bootflash, slot0, workspace.
dir bootflash=
16843 Jan 31 2022 15:16:05   lost+found/
Usage for bootflash: filesystem
 117481472 bytes used
1533422366 bytes free
1682349859 bytes total
switch(boot)#
dir slot0=
 90677248 used
328753152 free
419430400 total
dir workspace=
Could not access directory
switch(boot)#
NTFS  not going to work, Format with FAT or FAT 32 and try.
BB
Tried the same USB with FAT32 format, same error as before:
switch(boot)# dir slot0:
xxxx bytes used
xxxx bytes free
xxxx bytes total
Slot 0 is not the corresponding USB name, I receive the same message when the USB is removed from the port.
what size of USB, Try Fat 16 (if this is old nexus 5K, may be worth trying)
make sure USB is 8 or 16GB one.
BB
It's a newer USB drive of 8GB.
I'm not given the option to format it to FAT16 in the dialog box. If there's another way to format it to FAT16 then I can try that.
i do not believe anything more than 8GB can be formated Fat 16 (or FAT). or get 4GB USB
Only Option we have here TFTP.
BB
I've just used diskpart to create a primary active partition of 4GB on the USB and it has allowed a FAT format. I still get no option for the directory for usb drives.
As mentioned, my TFTP error cuts out without beginning:
switch(boot)#"
IP details remain similar to before the unit was booted into kickstarter. I am unable to modify the default gateway (I don't need or want to, but still receive an error message if I try)
Sergiu.Daniluk
Hi @SpaceAceFrehley
Can you check the following command in boot prompt:
"show interface m0"
if it is down or disabled you can enable it with:
conf t
interface m0
no shut
and then try again to copy the image.
Also, have you tried using ftp instead of tftp?
Take care,
Sergiu
Hi Sergiu,
 Output for "show interface m0":
mgmt0 is up
switch(boot)#
I've not used FTP before, I am prompted with a username but cannot login with default cisco/cisco or admin/admin-type credentials.
I have tried TFTP again after confirming that the port is up, but with no success.
