I've been trying to terminate multiple VLANs in AWS instance of CSR1000v. The scenario is like this:
VLAN 400 [CPE] --(L2)-- CSR1000v [Remote PoP] --- (L3 Link) -- CSR1000v [AWS] (SVI 400)
I've tried VXLAN between remote end CSR1000v and AWS CSR1000v but due to certain limitation in VXLAN implementation (I believe) you can't terminate vlan on the same box after decapsulating the vxlan.
Testing the scenario in lab (VMWare) works fine IF I connect something else with AWS CSR1000v via layer 2 and terminate the VLAN on that box in following way:
VLAN400 [CPE] -- (L2) -- CSR1000v [Remote PoP] --- (L3 Link) --- CSR1000v [AWS] --- (L2) --- CSR1000v [CPE] VLAN 400
Remote PoP CSR1000v:
redundancy
mode none
bridge-domain 400
member vni 400400
member GigabitEthernet3 service-instance 1
interface Loopback0
ip address 2.2.2.1 255.255.255.255
interface nve1
no ip address
member vni 400400
ingress-replication 2.2.2.2
source-interface Loopback0
interface GigabitEthernet2
ip address 1.1.1.1 255.255.255.252
interface GigabitEthernet3
no ip address
service instance 1 ethernet
encapsulation dot1q 400
rewrite ingress tag pop 1 symmetric
router bgp 65000
bgp log-neighbor-changes
redistribute connected
neighbor 1.1.1.2 remote-as 65001
AWS CSR1000v:
redundancy
mode none
bridge-domain 400
member vni 400400
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface nve2
no ip address
member vni 400400
ingress-replication 2.2.2.1
ip address 1.1.1.2 255.255.255.252
no ip address
router bgp 65001
neighbor 1.1.1.1 remote-as 65000
The problem is AWS doesn't offer any L2 connectivity between the instances so I can't replicate what I've done in LAB. Please correct if am doing something wrong here. Any other options instead of VXLAN?
