DCI 10 gig connection with Encryption
pratheesh.venu
We are designing a 10 gig DCI interconnect between two DCs which are 800 miles apart in US. Please share your input on settig up a layer two link with data encryption.
I am trying to address the following questions:
Is there a distance limit for VSL solution and will it support 10 Gig?
Do IP MPLS offer 10 Gig connectivity across DCs (approximately 800 Miles in US) ?
Does Nexus support vPC with MACSec(802.1 AE) across the DC? If yes, how would it handle reassembling of  encrypted frames traversing across two separate links?
I understand MACSec will add approximately 32 bytes per each frame. What would be the approximate throughput degradation on a 10 Gig DCI with encryption?
Industry best practice on setting up encryption for 10 gig DCI links
Thank You
Pratheesh
Oleksandr Nesterov
Hello Paratheesh
Here is the link that describes TrustSec implementation on N7k platform:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/security/configuration/guide/b_Cisco_Nexus_7000_NX-OS_Security_Configuration_Guide__Release_5.x_chapter_01101.html
And Cisco Data Center Interconnect Design and Deployment guide:
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/DCI/DCI2_External.pdf
Check page 69 for config sample.
HTH,
Alex
