Design of Nexus 7k with 2 vdc to nexus 5k
Lim Victor
Hi all,
I have a pair of nexus 7k with 2VDCs. The 2 vdcs have their own vlans.(vlan A - vlan100 to 199 and vdc B -  vlan 200 - 299). I have another pair of n5k.
We are trying to do an enhanced vpc design with the 2vdcs to the pair of N5Ks. Would there be any problems or anything I should take note?
Should or must the 5ks be connected to the 7ks using double-sided vpc topology? Is it possible since the 7ks have 2 vdcs?
Thanks.
Oleksandr Nesterov
Hi Lim
The vdcs are isolated one from another - so in order to have a connectivity to both of them you iwll need to connect your n5k to each of them with separate link.
vdc1    vdc2
      N5k
HTH,
Alex
Oleksandr Nesterov
Hi Lim
vdc1    vdc2
      N5k
HTH,
Alex
Thanks Alex
