Dual/double side vpc--->three/four side VPC
fly
Level 2
Level 2
customer want layer2 connect to two data center.
is there any possible to use three/four "side" VPC and form a loop free architecture for this two data center?
thank you!
tom
6 Replies 6
Collin Clark
If you have a layer 3 link between DC's today and you need to extend layer 2 across them, then you'll want to use OTV.
Hope it helps.
we design a new data center, want to use vpc across two data center, so double side VPC is not a method , we need 4 layer "side" VPC, is this design good or is there any problem, is it possible?
thank you!
Jeremy
Sorry, I have no idea what you are talking about. Do you have link to something similar or a diagram or something?
i draw a picture!
Is this possible?
That design doesn't make any sense. You can contact Partner help and they will gather your requirements and come up with a design.
http://www.cisco.com/web/partners/support/index.html
thank you!
I know this is not a good design, it is a discussion,  i can't agree customer choice,but customer eventullay choose this design, he want to use vpc connect two data center.
 thank you!
