FEX vPC displays status down from Show interface command
grettel.aviles
Hi all,
I'm currently deploying a couple of Nexus 2K in vPC (Enhanced vPC essentially) to a pair of Nexus 7K. the FEX went online on both parent switches and the port-channels and physical ports appear to in the UP state.
What puzzles me is that when I display the "show interface PoX" command, the vPC status appears to be down, whereas when displaying the "show vpc" command, the vPC ID corresponding the both FEXs say it's successfully up. I'm wondering if this behavior is expected (since these is are newly deployed devices, and therefore have no hosts connected yet) or if maybe I'm missing something else. I'm attaching both the physical diagram plus the configuration applied on the Nexus 7K.
PS. I already had other vPCs up and running with other Cisco switches and working fine.
Please your help with your answers.
grettel.aviles
I'm attaching the configuration file...dunno why it deleted it.
