General questions on LDAP setup/configuration using Device Manager version 5.2(2) and Cisco NX-OS version 5.2(2) and 4.2(7b) on the MDS 9513 Mainframe Ficon and Fibre Channel switches.
Dave_Jaggernath
I'm trying to setup the LDAP Server but not having much success. .
I took some screen snapshot from our MDS 9513 Ficon Directors and MDS 9513 Fibre Channel Directors (below), the first entry below is our MDS 9513 Ficon Directors used by our Mainframe/Host environment and the second entry is our MDS 9513 Fibre Channel (PPRC) switches:
Cisco NX-OS(tm) m9500, Software (m9500-sf2ek9-mz), Version 5.2(2), RELEASE SOFTWARE Copyright (c) 2002-2011 by Cisco Systems, Inc. Compiled 12/30/2011 14:00:00
Cisco NX-OS(tm) m9500, Software (m9500-sf2ek9-mz), Version 4.2(7b), RELEASE SOFTWARE Copyright (c) 2002-2009 by Cisco Systems, Inc. Compiled 8/16/2010 13:00:00
When I tried to setup/configure the LDAP server on either our MDS 9513 Ficon Directors or MDS 9513 Fibre Channel switch via logon with Admin and then select > Security, followed by AAA and I do NOT see the LDAP selection ????
Any assistance would be very much appreciated, what is missing or are we not at the appropriate software/firmware level for LDAP support.
Thank you.
also, my e-mail address is:  dave.jaggernath@td.com
10 Replies 10
fvaninet
LDAP on NX OS was introduced with the 5.x train
In order to enable its from CLI do this:
feature ldap
Then you need to configure it according to documentation
Fausto
Hi, thank you very much, I really appreciate the update.  So just to clarify and make sure that I understand.
1. The version 4.2(7b) does NOT support LDAP.  We MUST be at level 5.x.
2. I reviewed the LDAP documentation and it appears that to configure LDAP we MUST use the CLI interface.  Is there are GUI option available to perform the LDAP configuration or we must use the CLI interface to perform the LDAP configuration.
Thank you, your response is very much appreciated.
Correct
Honestly, I always used the CLI to configure box level features...graphical tool are ideal when you want a fabric view or need to configure a fabric wide service (like zoning)
Fausto
Hi Fausto, thank you very much Sir for the quick fresponse, it's very much appreciated.  We'll do as you recommend for the LDAP feature and configuration.  Do you have any tips and useful documentation other than what Cisco provides (i.e. Cisco MDS 9000 Family NX-OS Security configurationg guide release 5.2).  that might assist me when setting up/configuring LDAP, sometimes there are tips/tricks that are not documented in the manual.
So, here's what we plan to do:
 We have an external LDAP Server with SSL Encryption for userid and password authentication on port 1500 with of course IP address and DNS.  Any useful tips Fausto would be greatly appreciated.  Thanks again Sir.
I would follow Cisco configuration guide. Default port for LDAP is 389 but that can be changed.
The one thing I wanna let you know though is that generally customers do not use SSL encryption since NX OS devices only need to search a directory server, and do not make any changes to it. For this reason, security concerns are automatically relaxed and any form of security is considered a not so needed complication.
Fausto
Hi Fausto, Thanks for all the updates.  Hope you has a nice and loing weekend.
Ok, so from my end, we'll use the external LDAP server which has SSL on a specific port for the bind.
I reviewed the Cisco configuration guide for LDAP and there is something that I don't understand, maybe its just me, but pehaps you can comment or let me know.  Once we enable LDAP and update the default for the call to our external LDAP server, how do we setup the userid to use LDAP instead the internal security.  This is the one thing that I'm not sure how to do.  Do you have any suggestions and/or examples how to setup a userid once LDAP is enable to switch from internal security to LDAP for the userid.  Thanks again.
feature ldap
ldap-server host 172.16.0.15 rootDN "cn=Administrator,cn=users,dc=mylab,dc=net" password 7 F15hg123 port 389
ldap search-map memberOfSAN
  userprofile attribute-name "department" search-filter "(&(memberOf=cn=SAN,ou=LAB-USERS,dc=mylab,dc=net)(sAMAccountName=$userid))" base-DN "DC=mylab,DC=net"
aaa group server ldap core1
  server 172.16.0.15
  ldap-search-map memberOfSAN
aaa authentication login default group core1
Hi Fausto, Thanks for all the updates, its very much appreciated.  If I ask silly question, please forgive me.  Its just that all our switches are in Production so when security is turned on I've to be 100% sure that I do NOT miss anything, this is the reason for all the questions, I hope you dont mind.
So we did the following LDAP configuration/line commands:
Dddddddd (config)# ldap-server host 49.26.26.1 rootDN "cn=davej,cn=users,host=b100,o=tdbank,c=ca"
Dddddddd (config)# ldap-server port 1419
Warning: Ldap global port configuration cli will be deprecated.
Dddddddd (config)# aaa group server ldap core1
Dddddddd (config-ldap)# server 49.26.26.1
Dddddddd (config-ldap)# aaa authentication login default group core1
Dddddddd (config)# ldap-server host 49.26.26.1 enable-ssl
Dddddddd (config)# show ldap-server
     timeout : 5
        port : 1419
    deadtime : 0
total number of servers : 1
following LDAP servers are configured:
    49.26.26.1:
                idle time:0
                test user:test
                test password:********
                test DN:dc=test,dc=com
        timeout: 5    port: 1419    rootDN: cn=davej,host=b100,o=tdbank,c=ca
        enable-ssl: true
When I tried to logon to this switch via Device Manager for userid davej for an LDAP call to external server of 49.26.26.1, we do NOT see any messages in the LDAP server log.  Can you please see from the above config command and setup of LDAP, did we miss a step or forgot to enable any additional options.
Thank you Sir.
I'm not sure I can really help you further on this and maybe a Cisco TAC engineer would serve you best.
My advice is this:
disable SSL to start with
Use telnet/SSH and not device manager to make your tests. I remember a while back Device Manager was a bit peculiar and some proxy capability was enabled with it
Hope you can get to happy ending
Hi, thank you Fausto for all you assistance and suggestion.  I'll engage our support team and request a Cisco TAC engineer.  Have an excellent day.
