VSS STANDBY SUPERVISOR MODULES NOT GETTING UP.
aslam mohammad
hi folks,
Recently I Have configured VSS in cat 6509 switch in my data center after completion of all configuration both switches standby supervisors getting red color lights.
 I observed that standby supervisor goes to rommon mode.
I have attached output document so please verify and give me some tips to resolve this problem.
rommon 2 >
rommon 2 > confreg 0x2102
You must reset or power cycle for new config to take effect
rommon 3 > reset
Resetting .......
System Bootstrap, Version 12.2(50r)SYS3, RELEASE SOFTWARE (fc1)
Copyright (c) 2012 by cisco Systems, Inc.
PYRAMID platform with 2097152 Kbytes of main memory
Autoboot executing command: "boot bootdisk:s2t54-advipservicesk9-mz.SPA.150-1.SY7.bin"
bootdisk:%s72044-atafslib-m: Digitally Signed Release Software with key version A
Initializing ATA monitor library...
bootdisk:s2t54-advipservicesk9-mz.SPA.150-1.SY7.bin: Digitally Signed Release Software with key version A
Self extracting the image... [OK]
Self decompressing the image :
######################################################################################################### [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, s2t54 Software (s2t54-ADVIPSERVICESK9-M), Version 15.0(1)SY7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 24-Jul-14 11:04 by prod_rel_team
Image text-base: 0x04000144, data-base: 0x0C000000
System detected Virtual Switch configuration...
 Interface TenGigabitEthernet 1/5/4 is member of PortChannel 200
 Interface TenGigabitEthernet 1/5/5 is member of PortChannel 200
 Interface TenGigabitEthernet 1/6/4 is member of PortChannel 200
 Interface TenGigabitEthernet 1/6/5 is member of PortChannel 200
*Aug  4 06:27:33.807: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
Firmware compiled 25-Jun-14 09:42 by integ Build [25856]
*Aug  4 06:27:33.807: %PFREDUN-6-STANDBY: Initializing as STANDBY processor for this switch
*Aug  4 06:27:40.675: %SYS-SW1_STBY-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Aug  4 06:27:34.107: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
*Aug  4 06:27:40.675: %PFREDUN-SW1_STBY-6-STANDBY: Initializing as STANDBY processor for this switch
*Aug  4 06:27:41.047: %SYS-SW1_STBY-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
*Aug  4 06:27:41.055: SW1_STBY: vs_ha_send_hb_start_msg:Sending start req with
MyEobcAddr   : 262
Frequency    : 1000
Timeout      : 179000
Version      : 1
*Aug  4 06:27:41.055: SW1_STBY: vs_ha_ps_bootup_icc_msg_hdlr:** PSEUDO STDBY NOT SUPPORTED DROPPING TO ROMMON **
*Aug  4 06:27:41.055: %PFREDUN-SW1_STBY-4-SUP_FORCE_TO_ROMMON: Supervisor forced to rommon with reason: Cannot continue...
disabling autoboot and resetting
Resetting .......
rommon 1 >
65K01#sh switch virtual redundancy
                  My Switch Id = 1
                Peer Switch Id = 2
        Last switchover reason = none
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = sso
Switch 1 Slot 5 Processor Information :
        Current Software state = ACTIVE
       Uptime in current state = 3 days, 17 hours, 13 minutes
                 Image Version = Cisco IOS Software, s2t54 Software (s2t54-ADVIP        SERVICESK9-M), Version 15.0(1)SY7, RELEASE SOFTWARE (fc3)
                          BOOT = bootdisk:s2t54-advipservicesk9-mz.SPA.150-1.SY7        .bin,12;bootdisk:s2t54-advipservicesk9-mz.SPA.150-1.SY3.bin,12;
                   CONFIG_FILE =
                       BOOTLDR =
        Configuration register = 0x2102
                  Fabric State = ACTIVE
           Control Plane State = ACTIVE
Switch 2 Slot 5 Processor Information :
        Current Software state = STANDBY HOT (switchover target)
       Uptime in current state = 4 minutes
                   CONFIG_FILE =
                       BOOTLDR =
           Control Plane State = STANDBY
65K01#sh switch virtual link
VSL Status : UP
VSL Uptime : 7 minutes
VSL SCP Ping : Pass
VSL ICC Ping : Pass
VSL Control Link : Te1/5/5
VSL Encryption : Configured Mode - Off, Operational Mode - Off
HBDCITZWSL65K01#sh red
HBDCITZWSL65K01#sh redundancy s
HBDCITZWSL65K01#sh redundancy st
HBDCITZWSL65K01#sh redundancy states
       my state = 13 -ACTIVE
     peer state = 8  -STANDBY HOT
           Mode = Duplex
           Unit = Primary
        Unit ID = 21
Redundancy Mode (Operational) = sso
Redundancy Mode (Configured)  = sso
Redundancy State              = sso
     Maintenance Mode = Disabled
    Manual Swact = enabled
 Communications = Up
   client count = 137
 client_notification_TMR = 30000 milliseconds
          keep_alive TMR = 9000 milliseconds
        keep_alive count = 0
    keep_alive threshold = 18
           RF debug mask = 0x0
regards
aslam
aukhadiev
apparently your configuration VSS is quad supervisors VSS (VS4O)...
VS4O is available for Sup2T beginning with Cisco IOS Software Release 15.1(1)SY1.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-1SY/config_guide/sup2T/15_1_sy_swcg_2T/virtual_switching_systems.html#96603
You IOS Release is 15.0(1)SY7...
