Bookmark
Subscribe
1769
How to delete a VLAN in Hyperflex
We have an unused vlan named vmnet.VLAN026 in vswitch-hx-vm-network, it doesn't have any VM attached at this moment and we need to know what is the correct procedure in Hyperflex.
Thanks in advance,
Omar De Souza.
Kirk J
If you no longer have any plans to use it again, and are just cleaning up, then you will want to do the following:
  • Remove Port-group for that vlan from vswitch-hx-vm-network
  • uncheck/remove vlan from the UCSM vnic template (likely called vNIC Template vm-network-a)
    • This will be on LAN tab,,, under policies, your suborg, vnic templates, click 'modify vlans'
  • Once you have removed the vlan from being referenced by vnic templates, then you can remove it from the vlan global list
    • Lan Tab, LAN cloud, VLANs
Kirk...
Kirk J
Kirk...
Hi Kirk,
Many thanks for your answer.
Omar De Souza.
