HyperFlex and Hyper-v 2016 question
techspm1
I need to know, if Hyper-V 2016 is supported on Cisco HyperFlex and if you also support more than 1 hyper-v cluster running on the same Hyperflex "cluster" .... and if you support it and there is a upgrade to Hyper-v or the Hyperflex sw... will there be downtime?
techspm1
Can somebody give me an answer to this?
