Dears,
Could you advise with the heat dissipation of the following devices because it is not listed in their datasheets or specs:
FPR2130-FTD-HA-BUN (FPR2K-PWR-AC-400)
BE6M-M5-K9 (BE6K-PSU)
C9500-24Q-A (PWR-C4-950WAC-R)
UCSS-S3260 (UCSC-PSU1-1050W)
HXAF-SP-220M5-V (HX-PSU1-770W)
N9K-C93180-EX-B24C (NXA-PAC-650W-PE)
If any document is available with the heat dissipation of any of them, please kindly share it too.
Solved! Go to Solution.
The unit for Heat dissipation is BTU/hr.
The conversion from watts to BTU/hr is 1W = 3.412 BTU/hr. So, for example, a server that consumes 100W produces approximately 341.2 BTU/hr of heat energy.
Some datasheets have BTU mentioned,
I was able to find below ,
C9500-24Q - 2900 BTU/hr
Rest of the items , conversion of 1W = 3.412 BTU/hr might be needed.
Hope this helps ,
Please rate helpful posts ,
Hope this helps ,
