Hyperflex Cluster management with Nested vCenter
silviomanziano
I have 3 new sites that are being deployed.   Could I setup 1 nested vCenter in Hyperflex Cluster A,  so its managing the hosts in Cluster A,    then also setup Cluster B and C, and register them with the vCenter in Cluster A  ?    Basically trying to understand if there is any limitations on what the vcenter can manage.
Kirk J
Yes, you can have multiple HX clusters registered with the same vcenter.
Other than making sure you have all the allowed ports open, if firewalls are in play, you should be fine.
Also, you will have to manually power on the vcenter guestVM in the event your nested vcenter cluster has power outage that takes the cluster offline.
Kirk...
