10-01-2017 12:53 PM - edited 03-01-2019 08:37 AM
Hi Everyone
I deployed HX system encounter a question.
When i deploy hx installer ,that is is failed ,below errors ,why
Deploying Storage Controller VM on ESXi Host
Installing Software VIB on ESXi Host failed with ' [DependencyError] File path of '/opt/springpath/vm_services.py' is claimed by multiple non-overlay VIBs: set(['Springpath_bootbank_stHypervisorSvc_2.5.1b-26284', '_bootbank_scvmclient_2.1.1c-21048']) File path of '/opt/springpath/vm_ops.py' is claimed by multiple non-overlay VIBs: set(['Springpath_bootbank_stHypervisorSvc_2.5.1b-26284', '_bootbank_scvmclient_2.1.1c-21048']) File path of '/opt/springpath/vm_reparent.py' is claimed by multiple non-overlay VIBs: set(['Springpath_bootbank_stHypervisorSvc_2.5.1b-26284', '_bootbank_scvmclient_2.1.1c-21048']) File path of '/opt/springpath/support/SAMPLE.VscsiStats' is claimed by multiple non-overlay VIBs: set(['Springpath_bootbank_stHypervisorSvc_2.5.1b-26284', '_bootbank_scvmclient_2.1.1c-21048']) File path of '/opt/springpath/support/collectVscsiStats.sh' is claimed by multiple non-overlay VIBs: set(['Springpath_bootbank_stHypervisorSvc_2.5.1b-26284', '_bootbank_scvmclient_2.1.1c-21048']) File path of '/opt/springpath/support/README.VscsiStats' is claimed by multiple non-overlay VIBs: set(['Springpath_bootbank_stHypervisorSvc_2.5.1b-26284', '_bootbank_scvmclient_2.1.1c-21048']) Please refer to the log file for more details.'
Solved! Go to Solution.
10-26-2017 12:25 PM
Hi Shu Shen,
This can happen if you try to install an older version of HXDP on top of an ESXi installation that was used with a newer version of HXDP. You can quickly resolve this by re-imaging your ESXi host using the Cisco custom ISO posted on Cisco.com. TAC can also assist in manually removing the VIBs if you do not desire to re-image ESXi (typically a quick process).
10-02-2017 10:05 AM
shu shen,
I recommend you also post this to the Cisco Support Community for additional feedback and information from technical experts.
Cisco Support Community - Cisco Support Community
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
10-26-2017 12:25 PM
Hi Shu Shen,
