hyperflex host vcenter migration
jonobola7
How to migrate host's hyperflex to another VCENTER?
jgorlin
It is quite straightforward to move your HX deployment to a new vCenter. You simply need to run the 'stcli cluster reregister' command from the shell of any controller VM.
The full procedure is covered in here (requires CCO login to access). If the link does not work, you can find the procedure in the Managing HX Storage Clusters chapter of the HyperFlex Administration Guide.
James Lake
I am also looking to do this. A customer installed an HX using one vCenter now they would like to migrate to another vCenter.
jgorlin
even though a reregister reports successful, within Hyperflex I am showing "cluster invalid state" and "vm clone jobs not found".  Also I dont see the HX plugin in the new vcenter.  I am not finding reference to some additional post install steps to take to get these configuration items addressed.
