12-22-2023 06:39 AM
This is an older set of hardware in our lab, otherwise I would opened a TAC case, hoping someone may have some ideas. One of nodes had a power issue and apparently the storage controller vm got hosed. When it boots this message comes on the console.
boot disk not found fake mounted
Do I just need to completely remove the node from the cluster, wipe it, and expand the cluster?
12-22-2023 12:27 PM
Hi @smorgan_byte ,
It's a pity you can't open a TAC case for this. Based on reading the Cisco HyperFlex Data Platform CLI Guide, 4.0, I note:
IMPORTANT: Use the stcli node remove command to permanently remove a node from the cluster. Do not run the stcli node remove command if you intend to add the same node back into the same cluster later. Adding a node back into a cluster that it was already part of is not supported.
So your idea of "remove the node from the cluster, wipe it, and expand the cluster" may not work as well as intended.
01-02-2024 10:58 AM
TAC assists with similar requests that are usually triggered by boot drive failures, etc.
The high level steps involve:
If TAC case is not an option, you might want to see what a cluster redeploy would take (i.e. alternate space to park your guestVMs temporarily, or backup/restore).
For redeploy, you would want to reimage all your nodes with Hyperflex customized ESXi ISO, use the HX installer ova appliance for regular deployment.
@RedNectar is right, trying to re-use same node, after doing node remove will not work.
Kirk...
