08-07-2014 03:03 AM - edited 03-01-2019 07:37 AM
Actually we have the diagram connectivity but when try to activated port-channel 70 the LACP is suspended and only on mode ON is possible the communication
ethernet 5/33 is down (suspended(no LACP PDUs))
admin state is up, dedicated interface
Show port channel summary
Flags: D-Down P-Up in port-channel (member)
I-Individual s-suspended
S-Switched
Group Port channel type protocol member port
70 Po70(SD) Eth LACP Eth5/33(s) Eth5/34 (s)
Do you know something about this error, we try to force the negotiation on LACP but is the same error.
Best regards
08-07-2014 03:37 PM
Duplicate post.
Go here: https://supportforums.cisco.com/discussion/12273836/lacp-suspended-between-n7k-and-n2k
08-13-2014 06:36 AM
With FEX you use don't use the mode active.
Interface eth5/33
switchport mode fex-fabric
channel-group 70
The FEX uses a "Fabric" header on the link, and doesn't require LACP. You can use LACP on any host ports on the FEX, just not on the fabric links.
