Hi All
I have a question around SSL Concurrent sessions on ACE 20. According to the table "Security-Related Limits" from the following link:
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_(ACE)_Troubleshooting_Guide_--_ACE_Resource_Limits
Concurrent SSL conn supported is 100K.
My question is, does that number decrease depending on the RSA Keys Size. For example for 512 bit RSA, max concurrent conn is 100K but for 2048 bit RSA, would it be significantly less?
Appreciate your inputs.
AO
