N2K-C2232PP-10GE || SOHMS_DIAG_ERROR & SOHMS_PS_GPIO
sridharanb
Hi All,
I've N2K connected to N5K in single home. We purchased GLC-T for Nexus 2k to connect the 1G servers. I observed the following error and then, the PS is showing 'absent' in the environmental output... I'm wondering whether the change in speed to 1G forced this behaviour or it is due to some other issue. Can you please suggest to proceed... Thanks
NX-OS Version 5.1(3)N1(1a)
2012 Mar 21 11:48:42 Switch last message repeated 41 times
2012 Mar 21 11:48:42 Switch %SATCTRL-FEX122-2-SOHMS_DIAG_ERROR: FEX-142 Module 1: Runtime diag detected major event: GPIO access failure
2012 Mar 21 11:48:46 Switch %SATCTRL-FEX122-4-SOHMS_PS_GPIO: FEX-121 System PS access failure on Power supply: 1
2012 Mar 21 11:48:47 Switch %SATCTRL-FEX122-4-SOHMS_PS_GPIO: FEX-121 System PS access failure on Power supply: 2
Switch# sh environment fex 122
Temperature Fex 122:
Module   Sensor     MajorThresh   MinorThres   CurTemp     Status
                    (Celsius)     (Celsius)    (Celsius)
1        Outlet-1   71            50           33          ok
1        Inlet-1    70            55           30          ok
1        Die-1      92            75           41          ok
Fan Fex: 122:
Fan             Model                Hw         Status
Chassis         N2K-C2232-FAN        --         ok
PS-1            --                   --         absent
PS-2            --                   --         absent
Power Supply Fex 122:
Voltage: 12 Volts
PS  Model                Power       Power     Status
                         (Watts)     (Amp)
1   --                        --        --     absent
2   --                        --        --     absent
Mod Model                Power     Power       Power     Power       Status
                         Requested Requested   Allocated Allocated
                         (Watts)   (Amp)       (Watts)   (Amp)
1    N2K-C2232PP-10GE    0.00      0.00        0.00      0.00        powered-up
Power Usage Summary:
Power Supply redundancy mode:                 redundant
Total Power Capacity                                0.00 W
Power reserved for Supervisor(s)                    0.00 W
Power currently used by Modules                     0.00 W
Total Power Available                               0.00 W
Switch# sh diagnostic result fex 122
FEX-122: Fabric Extender 32x10GE + 8x10G Module  SerialNo   : SSI154309SK
Overall Diagnostic Result for FEX-122  : OK
Test results: (. = Pass, F = Fail, U = Untested)
TestPlatform:
0)              SPROM: ---------------> .
1)   Inband interface: ---------------> .
2)                Fan: ---------------> .
3)       Power Supply: ---------------> .
4) Temperature Sensor: ---------------> .
Eth    1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16
Port -------------------------------------------------
Eth   17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
TestFabricPorts:
Fabric 1  2  3  4  5  6  7  8
Switch# sh diagnostic result module all
Current bootup diagnostic level: complete
Module 1: O2 48X10GE/Modular Supervisor  SerialNo : FOC15504VHR
  Overall Diagnostic Result for Module 1 : PASS
  Diagnostic level at card bootup: complete
  Test results: (. = Pass, F = Fail, I = Incomplete,
                 U = Untested, A = Abort)
     1) TestUSBFlash ------------------------> .
     2) TestSPROM ---------------------------> .
     3) TestPCIe ----------------------------> .
     4) TestLED -----------------------------> .
     5) TestOBFL ----------------------------> .
     6) TestNVRAM ---------------------------> .
     7) TestPowerSupply ---------------------> .
     8) TestTemperatureSensor ---------------> .
     9) TestFan -----------------------------> .
    10) TestVoltage -------------------------> .
    11) TestGPIO ----------------------------> .
    12) TestInbandPort ----------------------> .
    13) TestManagementPort ------------------> .
    14) TestMemory --------------------------> .
    15) TestFabricEngine :
   Eth    1  2  3  4  5  6  7  8  9 10 11 12 13 14 15 16 17 18 19 20
   Port ------------------------------------------------------------
   Eth   21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
   Eth   41 42 43 44 45 46 47 48
    16) TestFabricPort :
    17) TestForwardingEngine :
    18) TestForwardingEnginePort :
    19) TestFrontPort :
Module 2: O2 GEM with L3 ASIC  SerialNo : FOC15476X9K
  Overall Diagnostic Result for Module 2 : PASS
     1) TestSPROM ---------------------------> .
     2) TestLED -----------------------------> .
     3) TestTemperatureSensor ---------------> .
     4) TestFabricEngine :
     5) TestFabricPort :
     6) TestForwardingEngine :
     7) TestForwardingEnginePort :
     8) TestFrontPort :
Sri
Colby Beam
Is it possible to try reseating these power-supplies? If this still does not resolve the issue, you may need to open a TAC case for this.
Colby Beam
Hi Colby,
Yes, we already did it and Cisco is going to RMA the box. We are yet to get the RCA for this.. Thanks for your time and efforts.
Sri
Hi Sri,
Just wonder if there is RCA for this? Is it hardware issue or?
Thanks.
Paul
