N2K-C2248TP-E-1GE goes offline
juan.barreto
Hello, Actually, I have a Nexus 5K with an N2K-C2248TP-E-1GE. When I insert other N2K-C2248TP-E-1GE it goes to Download image state and the first one goes to offline state. Some minutes later both goes to online status. Is it a normal operation?
FEX         FEX           FEX              FEX              Fex
Number    Description      State            Model            Serial
101        FEX0101                Offline   N2K-C2248TP-E-1GE   FOX2039GE9H
102        FEX0102                Download imagen   N2K-C2248TP-E-1GE   FOX2039GEH7
switch# sho run
!Command: show running-config
!Time: Thu Apr 26 21:48:53 2012
version 7.1(4)N1(1)
hostname switch
feature telnet
feature pim
feature interface-vlan
feature lldp
feature fex
username admin password 5 $1$nJjnpK7n$YI00OS0/yhCXurrVlGTSI0 role network-admin
no password strength-check
ip domain-lookup
fex 101
pinning max-links 1
description "FEX0101"
diagnostic bootup level complete
fex 102
pinning max-links 1
description "FEX0102"
vlan configuration 20
ip igmp snooping querier 172.16.20.1
vlan 1, 20
vrf context management
interface Vlan1
interface Vlan20
no shutdown
ip address 172.16.20.1/24
interface port-channel101
switchport mode fex-fabric
fex associate 101
interface port-channel102
fex associate 102
interface Ethernet1/1
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet1/4
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
interface Ethernet1/26
interface Ethernet1/27
interface Ethernet1/28
interface Ethernet1/29
interface Ethernet1/30
interface Ethernet1/31
fex associate 101
channel-group 101
interface Ethernet1/32
fex associate 102
channel-group 102
interface mgmt0
vrf member management
interface Ethernet101/1/1
interface Ethernet101/1/2
interface Ethernet101/1/3
interface Ethernet101/1/4
interface Ethernet101/1/5
interface Ethernet101/1/6
interface Ethernet101/1/7
interface Ethernet101/1/8
interface Ethernet101/1/9
interface Ethernet101/1/10
interface Ethernet101/1/11
interface Ethernet101/1/12
interface Ethernet101/1/13
interface Ethernet101/1/14
interface Ethernet101/1/15
interface Ethernet101/1/16
interface Ethernet101/1/17
interface Ethernet101/1/18
interface Ethernet101/1/19
interface Ethernet101/1/20
interface Ethernet101/1/21
interface Ethernet101/1/22
interface Ethernet101/1/23
interface Ethernet101/1/24
interface Ethernet101/1/25
interface Ethernet101/1/26
interface Ethernet101/1/27
interface Ethernet101/1/28
interface Ethernet101/1/29
interface Ethernet101/1/30
interface Ethernet101/1/31
interface Ethernet101/1/32
interface Ethernet101/1/33
interface Ethernet101/1/34
interface Ethernet101/1/35
interface Ethernet101/1/36
interface Ethernet101/1/37
interface Ethernet101/1/38
interface Ethernet101/1/39
interface Ethernet101/1/40
interface Ethernet101/1/41
interface Ethernet101/1/42
interface Ethernet101/1/43
interface Ethernet101/1/44
interface Ethernet101/1/45
interface Ethernet101/1/46
interface Ethernet101/1/47
interface Ethernet101/1/48
interface Ethernet102/1/1
interface Ethernet102/1/2
interface Ethernet102/1/3
interface Ethernet102/1/4
interface Ethernet102/1/5
interface Ethernet102/1/6
interface Ethernet102/1/7
interface Ethernet102/1/8
interface Ethernet102/1/9
interface Ethernet102/1/10
interface Ethernet102/1/11
interface Ethernet102/1/12
interface Ethernet102/1/13
interface Ethernet102/1/14
interface Ethernet102/1/15
interface Ethernet102/1/16
interface Ethernet102/1/17
interface Ethernet102/1/18
interface Ethernet102/1/19
interface Ethernet102/1/20
interface Ethernet102/1/21
interface Ethernet102/1/22
interface Ethernet102/1/23
interface Ethernet102/1/24
interface Ethernet102/1/25
interface Ethernet102/1/26
interface Ethernet102/1/27
interface Ethernet102/1/28
interface Ethernet102/1/29
interface Ethernet102/1/30
interface Ethernet102/1/31
interface Ethernet102/1/32
interface Ethernet102/1/33
interface Ethernet102/1/34
interface Ethernet102/1/35
interface Ethernet102/1/36
interface Ethernet102/1/37
interface Ethernet102/1/38
interface Ethernet102/1/39
interface Ethernet102/1/40
interface Ethernet102/1/41
interface Ethernet102/1/42
interface Ethernet102/1/43
interface Ethernet102/1/44
interface Ethernet102/1/45
interface Ethernet102/1/46
interface Ethernet102/1/47
interface Ethernet102/1/48
line console
line vty
boot kickstart bootflash:/n5000-uk9-kickstart.7.1.4.N1.1.bin
boot system bootflash:/n5000-uk9.7.1.4.N1.1.bin
Best Regards,
Mark Malone
Hi that's not normal it shouldn't be dropping your other fexs just because you add another one , that's fairly impactful issue it may be a bug
Your config looks ok too only thing is your missing your vpc number under the portchannel but your only using 1 5k so shouldn't be the issue as you don't need it  , bit concerning as im about to move to 7.1.4 in our 5ks and 7ks this weekend
There is no release notes online for that new nx-os image I can see , did you TAC it ?
