10-05-2015 07:20 AM - edited 03-01-2019 08:03 AM
Hi All,
I try to setup N2K extender from Parent switch N9K, but FEX is showing offline.
Any configuration I missing?
Please let me know.
Thank you.
N9K1# show run int eth2/1
!Command: show running-config interface Ethernet2/1
!Time: Mon Oct 5 14:05:38 2015
version 7.0(3)I1(3)
switchport mode fex-fabric
fex associate 141
channel-group 141
N9K1# show run int eth2/3
!Command: show running-config interface Ethernet2/3
!Time: Mon Oct 5 14:05:40 2015
version 7.0(3)I1(3)
fex associate 141
channel-group 141
N9K1# show run int po141
!Command: show running-config interface port-channel141
!Time: Mon Oct 5 14:05:48 2015
version 7.0(3)I1(3)
fex associate 141
N9K1# show fex
FEX FEX FEX FEX
Number Description State Model Serial
--- -------- Offline N2K-C2348UPQ-10GE FOC1846R0DS
N9K1# show int eth2/1-3 brief
Ethernet VLAN Type Mode Status Reason Speed Port
Interface Ch #
Eth2/1 1 eth fabric up none 40G(D) 141
Eth2/2 1 eth access down XCVR not inserted auto(D) --
Eth2/3 1 eth fabric up none 40G(D) 141
N9K1# show int eth2/1-3 status
Port Name Status Vlan Duplex Speed Type
Eth2/1 -- connected 1 full 40G QSFP-40G-SR-BD
Eth2/2 -- xcvrAbsen 1 auto auto --
Eth2/3 -- connected 1 full 40G QSFP-40G-SR-BD
N9K1#
10-06-2015 12:08 AM
According to the Supported FEX Modules section of the NX-OS 7.0(3)I1(3) release note, the Nexus 2348UPQ is not supported on the Nexus 9300 with the software version you're running.
For support you will need to upgrade to NX-OS 7.0(3)I2(1). See Supported FEX Modules from the NX-OS 7.0(3)I2(1) release note.
10-08-2015 11:11 PM
Hi Steve,
I will try this and let you know the result.
Thank you. :)
Collin
