10-05-2015 07:48 AM - edited 03-01-2019 08:03 AM
Software
BIOS: version 3.6.0
loader: version N/A
kickstart: version 7.0(1)N1(1)
system: version 7.0(1)N1(1)
Power Sequencer Firmware:
Module 1: version v5.0
Module 2: version v1.0
Module 3: version v1.0
Microcontroller Firmware: version v1.0.0.2
SFP uC: Module 1: v1.1.0.0
QSFP uC: Module not detected
BIOS compile time: 05/09/2012
kickstart image file is: bootflash:///n5000-uk9-kickstart.7.0.1.N1.1.bin
kickstart compile time: 3/19/2014 14:00:00 [03/19/2014 20:09:46]
system image file is: bootflash:///n5000-uk9.7.0.1.N1.1.bin
system compile time: 3/19/2014 14:00:00 [03/19/2014 23:54:43]
Nx-DstSrv_2-SPP# show proc cpu hist
223233223354534432332232332342233333322233332232333332332232
792522890459303359717935248977800761097941009817815137217916
100
90
80
70
60 #
50 ### #
40 ### ### # ## ## # #
30 ############################################################
20 ############################################################
10 ############################################################
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per second (last 60 seconds)
# = average CPU%
476654559654666558877977666848787888654655765655677646576456
906484346929180091568161700085196697478459609778917834838662
100 *
90 * * * * * ***
80 * ****** * * ***** * *
70 ** ** * ******** * **#**** * * **** **
60 **** ** *** ************ **#*###** ************* **** **
50 ***** ************#**#*********#*###**************** *******
40 **#*****#****#***#######***#*#*#####***#*****#****#****#****
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
Nx-DstSrv_2-SPP# [17D[J
Nx-DstSrv_2-SPP# show processes cpu history
332332333454632332332333332433332333332334333433323532333333
546428241230039238539330366652557540439524332031499206230730
100
90
80
70
60 #
50 # # # #
40 # #### # # ## ## # # # # ## #
0 5 0 5 0 5 0 5 0 5
# = average CPU%
668487878886546557656556776465764567647668565785577666658556
000851966974784596097789178348386626091276138229352558124816
100
90 * * *** *
80 * * ***** * * * * * * *
70 * **#**** * * **** ** * * ** ** ***** * *
60 *** **#*###** ************* **** **** **** ***** ****** ** *
50 ******#*###**************** ********************************
40 **#*#*#####***#*****#****#****#****#*****#**#*#****#****#***
0 5 0 5 0 5 0 5 0 5
888998988989888888888989989888998899998990
628339025120608887789181091956167436676860
100 * *** ***
90 * ***** ** ** ******************* ********
80 ******************************************
70 ******************************************
60 ******************************************
50 ******************************************
40 ***********#***********************#***#*#
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
Nx-DstSrv_2-SPP#
Nx-DstSrv_2-SPP#
Nx-DstSrv_2-SPP# show sys[25D[J
Nx-DstSrv_2-SPP# show sys[Jtem re[31D[J
Nx-DstSrv_2-SPP# show system re
redundancy reset-reason resources
[J
Nx-DstSrv_2-SPP# show system res[32D[J
[J
Nx-DstSrv_2-SPP# show system reso[33D[J
Nx-DstSrv_2-SPP# show system reso[Jurces
Load average: 1 minute: 2.75 5 minutes: 2.10 15 minutes: 1.86
Processes : 368 total, 4 running
CPU states : 35.1% user, 23.6% kernel, 41.3% idle
CPU0 states : 27.9% user, 14.4% kernel, 57.7% idle
CPU1 states : 42.3% user, 32.7% kernel, 25.0% idle
Memory usage: 8253860K total, 2665872K used, 5587988K free
Nx-DstSrv_2-SPP# show system resources [39D[J
543254232233233453233233233533233233333243233233233233233333
163588528808524245611611790200658693012874633810526736893154
100
90
80
70
60 #
50 ## ## # # #
40 ## ## # ### # # ## # # # # # #
0 5 0 5 0 5 0 5 0 5
# = average CPU%
100
90 * * *** *
0 5 0 5 0 5 0 5 0 5
100 * *** ***
C:\Users\CA>ping 10.94.0.2 -t
Haciendo ping a 10.94.0.2 con 32 bytes de datos:
Respuesta desde 10.94.0.2: bytes=32 tiempo=3ms TTL=253
Respuesta desde 10.94.0.2: bytes=32 tiempo=1ms TTL=253
Respuesta desde 10.94.0.2: bytes=32 tiempo=2ms TTL=253
Respuesta desde 10.94.0.2: bytes=32 tiempo=4ms TTL=253
Respuesta desde 10.94.0.2: bytes=32 tiempo=6ms TTL=253
Respuesta desde 10.94.0.2: bytes=32 tiempo=5ms TTL=253
Respuesta desde 10.94.0.2: bytes=32 tiempo=19ms TTL=253
Respuesta desde 10.94.0.2: bytes=32 tiempo=29ms TTL=253
Respuesta desde 10.94.0.2: bytes=32 tiempo=33ms TTL=253
Respuesta desde 10.94.0.2: bytes=32 tiempo=28ms TTL=253
Estadísticas de ping para 10.94.0.2:
Paquetes: enviados = 30, recibidos = 30, perdidos = 0
(0% perdidos),
Tiempos aproximados de ida y vuelta en milisegundos:
Mínimo = 1ms, Máximo = 33ms, Media = 5ms
Control-C
^C
Solved! Go to Solution.
10-08-2015 06:43 AM
I cannot say from the output if you are hitting this issue but can you validate if you have a 5596T platform?
https://tools.cisco.com/bugsearch/bug/CSCuo33078/?reffering_site=dumpcr
The workaround is listed in the bug if you have a 5596T.
Raj
10-05-2015 07:52 PM
Hi Manuel,
I see that you have posted a bunch of outputs. Can you also specifically state your question as well and I can help best answer it.
-Raj
10-07-2015 01:42 PM
I have problems with peak CPU.
I have these two processes that consume a lot of CPU. bcm_usd & carmelusd
Nx-DstSrv_2-SPP# show processes cpu | inclu carm
3327 160040604 236040101 678 21.3% carmelusd
3327 160041895 236042092 678 24.9% carmelusd
3327 160043957 236044425 678 22.6% carmelusd
3327 160048380 236051046 678 19.8% carmelusd
3327 160049382 236052568 678 22.8% carmelusd
Nx-DstSrv_2-SPP# show processes cpu | inclu bcm_usd
3331 104411 1232113 84 9.2% bcm_usd
3331 104414 1232137 84 10.3% bcm_usd
3331 104415 1232141 84 9.4% bcm_usd
PID Runtime(ms) Invoked uSecs 1Sec Process
1 9611 110751 86 0.0% init
2 2 306 9 0.0% kthreadd
3 27 5998 4 0.0% migration/0
4 27209 4324480 6 0.0% ksoftirqd/0
5 8324 109519 76 0.0% watchdog/0
6 28 5844 4 0.0% migration/1
7 29553 4148497 7 0.0% ksoftirqd/1
8 4607 109519 42 0.0% watchdog/1
9 42598 540633 78 0.0% events/0
10 16104 539176 29 0.0% events/1
11 2 104 21 0.0% khelper
12 27 41 668 0.0% netns
13 1 100 13 0.0% kblockd/0
14 2 223 9 0.0% kblockd/1
15 0 2 0 0.0% kacpid
16 0 2 0 0.0% kacpi_notify
17 28 9 3137 0.0% ksuspend_usbd
18 5 146 34 0.0% khubd
19 0 17 4 0.0% pdflush
20 642 76681 8 0.0% pdflush
21 0 2 0 0.0% kswapd0
22 0 2 0 0.0% aio/0
23 0 2 0 0.0% aio/1
24 0 2 0 0.0% nfsiod
25 0 2 0 0.0% kide/0
26 0 2 0 0.0% kide/1
29 0 2 0 0.0% scsi_eh_0
30 979 157955 6 0.0% usb-storage
32 0 2 0 0.0% rpciod/0
33 0 17 8 0.0% rpciod/1
34 639 141212 4 0.0% kirqd
439 19 3 6485 0.0% jffs2_gcd_mtd2
545 367 13965 26 0.0% kjournald
550 219 12744 17 0.0% kjournald
1262 286 16638 17 0.0% kjournald
1271 209 11988 17 0.0% kjournald
1790 1 30 38 0.0% portmap
1799 4 5 858 0.0% rpc.statd
1814 0 2 3 0.0% lockd
1815 0 103 3 0.0% nfsd
1816 0 101 3 0.0% nfsd
1817 0 100 3 0.0% nfsd
1818 0 101 3 0.0% nfsd
1819 0 102 3 0.0% nfsd
1820 0 101 3 0.0% nfsd
1821 0 100 3 0.0% nfsd
1822 0 103 3 0.0% nfsd
1827 0 1 120 0.0% rpc.mountd
1850 104798 2595571 40 0.0% sysmgr
2545 0 1 39 0.0% mping-thread
2780 186 35299 5 0.0% insmod
2810 98176 33214675 2 0.0% fcp_thread_intr
2909 0 2 2 0.0% bond0
3214 8 4 2078 0.0% xinetd
3215 4 4 1062 0.0% tftpd
3216 25126 498341 50 0.0% syslogd
3217 28 46 621 0.0% sdwrapd
3218 6098834 5021264 1214 0.8% pfma
3225 759 176434 4 0.0% ls-notify-mts-t
3231 39725 1096455 36 0.0% usd_mts_kthread
3238 0 1 8 0.0% pfm_gem_hp_kern
3242 2517 116370 21 0.0% vshd
3243 113 24 4710 0.0% smm
3244 4026 388394 10 0.0% psshelper
3245 319 8854 36 0.0% lmgrd
3246 7565 126786 59 0.0% licmgr
3247 197320 107529 1835 0.0% fs-daemon
3248 58636 2210745 26 0.0% feature-mgr
3249 1288 82897 15 0.0% fcfwd
3250 157 1904 82 0.0% confcheck
3251 1541 72179 21 0.0% capability
3252 4036 388375 10 0.0% psshelper_gsvc
3259 2315 22168 104 0.0% cisco
3263 24780 49443 501 0.0% clis
3281 159420 180017 885 0.0% port-profile
3282 1806 74576 24 0.0% provision
3294 3114 145701 21 0.0% zschk
3295 2864 142704 20 0.0% xmpp
3296 2262 141591 15 0.0% xmlma
3297 3030 144009 21 0.0% vmm
3298 1792 62166 28 0.0% vman
3299 2818 141773 19 0.0% vdc_mgr
3300 3329 201079 16 0.0% ttyd
3301 5732 86361 66 0.0% sysinfo
3302 13289 119785 110 0.0% sunnyvale
3303 369889 3159244 117 0.0% statsprofiler
3304 52 153 344 0.0% sksd
3305 194715 42328 4600 0.0% sensor
3307 440 10047 43 0.0% res_mgr
3308 6277 416777 15 0.0% plugin
3309 5536 184110 30 0.0% pltfm_config
3310 4999 82213 60 0.0% plog_sup
3311 18224 275754 66 0.0% pfstat
3312 1246 55396 22 0.0% obfl
3313 1725 74226 23 0.0% nohms
3314 79623 2178581 36 0.0% nfp
3315 1184 51335 23 0.0% mvsh
3316 3785 150734 25 0.0% mcm
3317 6089 412249 14 0.0% ledmgr
3318 11240 158105 71 0.0% ifmgr
3319 8350 137928 60 0.0% idehsd
3320 1080 49509 21 0.0% evms
3322 956 38262 24 0.0% evmc
3323 7521 153548 48 0.0% ethpc
3324 20478 361162 56 0.0% eth_dstats
3325 201 1626 124 0.0% core-dmon
3327 160100185 236126275 678 17.8% carmelusd
3328 2614 195289 13 0.0% bootvar
3329 4128 79062 52 0.0% bios_daemon
3330 4761 347808 13 0.0% bfdc
3331 104153 1228137 84 7.8% bcm_usd
3332 776 35483 21 0.0% athertonusd
3333 1070 52442 20 0.0% ascii-cfg
3334 687 25782 26 0.0% adbm
3335 4905 387194 12 0.0% securityd
3336 3247 60869 53 0.0% PMon
3337 4389 391101 11 0.0% cert_enroll
3338 6992 392628 17 0.0% aaa
3342 195 1347 144 0.0% l3vm
3343 147 130 1135 0.0% urib
3354 2435 17549 138 0.0% aclmgr
3357 21525 601923 35 0.0% qd
3358 11 19 607 0.0% core-client
3380 369859 2950295 125 0.0% fwm
3382 9968227 6878093 1449 17.0% statsclient
3384 6743022 25133990 268 0.0% snmpd
3398 31435 34524 910 0.0% copp
3401 195 1851 105 0.0% npacl
3404 133 50 2664 0.0% adjmgr
3406 165 1538 107 0.0% u6rib
3434 185 1324 139 0.0% arp
3435 138 175 790 0.0% icmpv6
3450 268 1371 195 1.5% pktmgr
3451 3007 144730 20 0.0% sal
3453 4930 391409 12 0.0% callhome
3482 306491 4995195 61 0.0% fex
3484 301531 3087245 97 0.0% lldp
3485 304 705 432 0.0% netstack
3512 10231 451335 22 0.0% radius
3514 1120 30424 36 0.0% acllog
3515 66951 546487 122 0.0% cdp
3517 1048717 19102590 54 0.0% cfs
3518 117 31 3793 0.0% ecp
3519 168 34 4947 0.0% igmp
3520 13 13 1073 0.0% ip_dummy
3521 14 16 885 0.0% ipv6_dummy
3522 154 63 2452 0.0% mrib
3523 3042 146474 20 0.0% otm
3524 183 1502 121 0.0% rpm
3525 13 13 1071 0.0% tcpudp_dummy
3561 234 2120 110 0.0% dcos-xinetd
3592 399600 6860798 58 0.0% hsrp_engine
3594 156 298 525 0.0% mcastfwd
3638 3832103 620441 6176 0.0% afm
3639 1121 39560 28 0.0% m2rib
3640 4164 154289 26 0.0% monitor
3641 545944 6354553 85 0.0% stp
3642 523 5740 91 0.0% ptplc
3650 44108 599456 73 0.0% eth_port_channel
3652 11921 75314 158 0.0% vlan_mgr
3653 1649 34679 47 0.0% ntp
3654 17134 61429 278 0.0% ipqosmgr
3655 65495 1534269 42 0.0% lacp
3657 23059 903341 25 0.0% ntpd
3658 2687253 12309681 218 0.0% ethpm
3659 55392 738047 75 0.0% interface-vlan
3660 61743 1207101 51 0.0% vpc
3663 34507 198656 173 0.0% btcm
3664 2512784 2750014 913 0.0% udld
3669 12914 264342 48 0.0% ipfib
3670 9751 117171 83 0.0% mfdm
3671 6585 179454 36 0.0% ufdm
3848 100815 33203371 3 0.0% fcp_thread_sm/0
3858 158 23507 6 0.0% wdpunch_thread
3882 133 43 3109 0.0% eigrp
3922 6 27 257 0.0% getty
3924 3 4 896 0.0% sh
3928 75 28 2679 0.0% libvirtd
4090 96019 33194755 2 0.0% fcp_thread_sm/1
4165 98716 33188549 2 0.0% fcp_thread_sm/2
4198 7 46 172 0.0% ppm
4208 0 2 2 0.0% kauditd
5699 2 50 44 0.0% klogd
17708 653 8405 77 0.0% dcos_sshd
17709 879 4406 199 0.0% vsh
18251 1 4 494 0.0% vsh
18252 36 4 9148 0.0% ps
CPU util : 14.0% user, 12.0% kernel, 74.0% idle
Please note that only processes from the requested vdc are shown above
Please help me with this.
regards,
Manuel
10-08-2015 06:43 AM
Raj
10-09-2015 06:56 AM
Thank you very much for your help!
