04-08-2010
09:37 AM
- last edited on
03-25-2019
01:28 PM
by
ciscomoderator
I need help with the concept of the vPC keepalive link. I am trying to get my head round some configs before the kit turns up which is on order...
I have seen a Cisco doc that says you can use an SVI for the keepalive link on the N5K, but how do you do that as I though the N5K was a L2 switch and the command references I have searched through dont show a the command: interface vlan x
Basically I am trying to work out how to manage this switch remotely and and get the Keepalive operational, but I dont have a separate dedicated management LAN to use (who does these days?). So if I have to use an SVI, that means it runs on a VLAN, which will have to cross the vPC PeerLink, and this I thought was a fundamental no-no of the vPC design rules: dont send the keepalive across the peerlink.
On the N7K I will use a dedicated L3 point-to-point fibre interface for the Keepalive as a I dont have a management LAN, so that seems easy enough, yes/no?
Thanks for any explanation attempts in advance...
04-12-2010 05:12 AM
Check out the below link for vpc configuration on nexus 5k hope that helps.
http://jasonnash.wordpress.com/2009/08/10/vpc-virtual-port-channel-and-the-nexus-platform/
Ganesh.H
If helpful do rate the post
04-13-2010 01:52 AM
Thanks for posting but your blog doesnt answer my concern. Your post shows using the mgmt0 port, which I know is what you can do, but without a seperate dedicated management LAN infrastructure how can I use it? If I just put a xover cable between them then I cant remotely connect to the switch as the IP addresses are on a private wire only. Im looking for an example of how to use an SVI instead of the mgmt0 interface, thanks.
05-17-2010 04:16 AM
you still need the answer or you solved this issue?
05-19-2010 02:25 AM
still looking for more info
05-19-2010 04:07 AM
I worked on the same thing last Week, and to separate The peer Link and the keepalive link:
Commun Config |
feature interface-vlan feature lacp feature vpc feature fex |
- I used one link 10Gig as trunk with a dedicated Intervace VLAN for a KeepAlive.
keepAlive Config |
------------------config for 1st N5K-------------------------------- vlan 900 name VLAN-KeepAlive no shutdown ! vpc domain 10 ! interface Ethernet1/33 ------------------config for 2nd N5K-------------------------------- vlan 900 name VLAN-KeepAlive no shutdown ! vpc domain 10 ! interface Ethernet1/33description To-5020-RDC-131-Eth1/33-KeepAlive switchport mode trunk switchport trunk allowed vlan 900 no shut exit ! |
- Two links 10Gig bundled in a portchannel on each N5K for pee link
Peer Link Config |
------------------config for 1st N5K-------------------------------- interface port-channel10 ------------------config for 2nd N5K-------------------------------- interface port-channel10 |
I used the interface VLAN 1 for management.
BR;
07-23-2010 06:34 PM
Do you have to use a seperate svi? Or could you use vlan 1 in your configuration?
04-30-2012 01:27 AM
Dear,
There is also some additionnal considerations to set up VPC peer keep-alive with a SVI:
Please find below recommandations from CISCO :
In an emulated switch setup, inband keepalive does not work. The following steps are recommended for peer keepalive over SVI when a switch is in FabricPath mode:
–Use a dedicated front panel port as a vPC+ keepalive. The port should be in CE mode.
–Use a dedicated VLAN to carry the keepalive interface. The VLAN should be CE VLAN.
–Add the management keyword to the corresponding SVI so that the failure of a Layer 3 module will not bring down the SVI interface.
–Enter the dual-active exclude interface-vlan keepalive-vlan command to prevent the SVI from going down on the secondary when a peer-link goes down
The "management" keyword have to be applied on the vlan interface (with dedicated VLAN), and "dual-active" command....
Because else interface VLAN is considered as a common forwarding interface.
Please find below the related link :
I hope it will be helpfull,
Best Regards,
