02-10-2011 04:56 AM - edited 03-01-2019 06:54 AM
what is the amount of the fabric modules i need in my Nexus 7000?
And is the amount of the fabric modules dependent of the I/O modules?
Thanks.
02-10-2011 09:26 AM
So the fabric module that we have on the nexus 7000 will supply 46gbps per slot for each module you add:
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/ps9512/Data_Sheet_C78-437760.html
Depending on the modules you are using will dictate how many fabrics you need. For example if you are using a N7K-M132XP-12L:
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/data_sheet_c78-605622.html
It has 80gb backplane connection, so to get full capabilitys of the module, you need 2 fabric modules. You would likely want 3 for N+1 redundancy.
However if you are using N7K-F132XP-15, it can make use of 230gb on the fabric...so for full capacity you would want 5 fabric modules:
Overall just check the datasheet for the modules you are using and by looking at switch fabric interface speed you should be able to plan out the number of fabrics you'll need for your cards.
Hope that helps
Chad
02-11-2011 05:50 AM
Hello Chad,
thanks, that was very helpful.
Have a great weekend.
