This article used a translator.
My N7k the bootflash has been corrupted.
This has been confirmed as follows.
This damage is going to use the recovery tools. (N7000-s2-flash-recovery-tool.10.0.2.tar)
But you can not use the NPE.
Tell us how
In my opinion
1. boot to non-npe images using USB
2. Use the Recovery tool.
3. Boot into recovery npe image.
Is that correct?
admin_vdc-Core_2# Show system internal raid
Current RAID status info:
RAID data from CMOS = 0xa5 0xf0
RAID data from driver disks 0 bad 0 name
Bootflash: /dev/sdc
Mirrorflash: /dev/sdb
Current RAID status:
Personalities : [raid1]
md6 : active raid1 sdb6[1]
77888 blocks [2/1] [_U]
md5 : active raid1 sdb5[1]
78400 blocks [2/1] [_U]
md4 : active raid1 sdb4[1]
39424 blocks [2/1] [_U]
md3 : active raid1 sdb3[1]
1802240 blocks [2/1] [_U]
unused devices: <none>
Bootup RAID status:
boot device node /dev/sdc
boot device mirror node /dev/sdb
obfl flash device node /dev/sdd
/dev/sdc access okay.
/dev/sdb access okay.
Writing 0 to CMOS
Sun Jun 26 12:13:11 2016: RAIDMON: Data(0x0) provided saved successfully to CMOS
Assembling RAID services...
mdadm: looking for devices for /dev/md3
mdadm: /dev/sdc3 is identified as a member of /dev/md3, slot 0.
mdadm: /dev/sdb3 is identified as a member of /dev/md3, slot 1.
mdadm: added /dev/sdc3 to /dev/md3 as 0
mdadm: added /dev/sdb3 to /dev/md3 as 1
mdadm: /dev/md3 has been started with 1 drive (out of 2).
mdadm: looking for devices for /dev/md4
mdadm: /dev/sdc4 is identified as a member of /dev/md4, slot 0.
mdadm: /dev/sdb4 is identified as a member of /dev/md4, slot 1.
mdadm: added /dev/sdc4 to /dev/md4 as 0
mdadm: added /dev/sdb4 to /dev/md4 as 1
mdadm: /dev/md4 has been started with 1 drive (out of 2).
mdadm: looking for devices for /dev/md5
mdadm: /dev/sdc5 is identified as a member of /dev/md5, slot 0.
mdadm: /dev/sdb5 is identified as a member of /dev/md5, slot 1.
mdadm: added /dev/sdc5 to /dev/md5 as 0
mdadm: added /dev/sdb5 to /dev/md5 as 1
mdadm: /dev/md5 has been started with 1 drive (out of 2).
mdadm: looking for devices for /dev/md6
mdadm: /dev/sdc6 is identified as a member of /dev/md6, slot 0.
mdadm: /dev/sdb6 is identified as a member of /dev/md6, slot 1.
mdadm: added /dev/sdc6 to /dev/md6 as 0
mdadm: added /dev/sdb6 to /dev/md6 as 1
mdadm: /dev/md6 has been started with 1 drive (out of 2).
