N7K OTV Unicast mode
khambright
Level 4
Level 4
We are setting up OTV on the N7K in unicast mode.  Do I still need IGMP v3 configured on the join interface ?  And then on the Other side of the Join interface does that interface need IGMP v3 enabled as well?
example
Production VDC:
interface port-channel8
  description to OTV-VDC-Join Interface
  mtu 1600
  ip address 172.23.1.213/30
  ip ospf network point-to-point
  ip router ospf 2 area 0.0.0.0
  ip igmp version 3
OTV VDC:
  description to Production-VDC _Join Interface
  mtu 1600
  ip address 172.23.1.214/30
ip igmp version 3
interface Overlay0
  otv join-interface port-channel8
  otv extend-vlan 201
  otv adjacency-server unicast-only
  no shutdown
sean_evershed
Level 7
Level 7
Have a look at this guide that provides a configuration example for Unicast mode
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/DCI/whitepaper/DCI_A.html
See below a snippet from the guide
interface Ethernet2/5
  description [ To the OTV Join-Interface ]
  ip address 172.26.255.97/30
  ip pim sparse-mode
  ip igmp version 3
  no shutdown
Don't forget to rate all helpful posts
richbarb
You still need a command "ip igmp ver 3", the only difference in the configuration point of view is in the Overlay Interface.
alex.baldwin
has anyone successfully got this to work?
