N7K-SUP1 EOL Replacement
Mokhalil82
Level 4
Level 4
Hi Guys
So not sure yet how the EOL process works, but I have a N7K with the SUP1 Supervisor (N7K-SUP1) and on the cisco website it shows the last day of support in 2019 on the link below, it also gives details of the replacement part being the SUP2. Does this mean I am still supported until 2019 or is it time to look for a SUP2
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/end_of_life_notice_c51-729282.html
2 Accepted Solutions
Steve Fuller
Level 9
Level 9
If you don't need to upgrade to Supervisor 2 for another reason i.e., it's a dependency for some other hardware or feature that you'll be using, then there's no absolute reason to move at this stage. As per the link you attached to the original posting, the Supervisor 1 is supported by Cisco until August 2019.
You will be supported till the last day of support mentioned in EOL announcement.
Steve Fuller
Level 9
Level 9
