NAC: Issue with Module "aci_rest_managed.mcpInstPol" during apply
matze123
Hi guys,
since a few days i have the issue that my terraform apply don't work anymore. A few weeks ago it worked fine and i don't changed any versions.
Anytime when i try to deploy Access Policies is see the following change:
  # module.aci.module.aci_mcp[0].aci_rest_managed.mcpInstPol will be updated in-place
  ~ resource "aci_rest_managed" "mcpInstPol" {
      ~ content    = {
          ~ "adminSt"        = "disabled" -> "enabled"
            # (7 unchanged elements hidden)
        id         = "uni/infra/mcpInstP-default"
        # (3 unchanged attributes hidden)
But i don't configure the MCP Policy in my yaml files and I want it to stay default (disabled).
During the deploy, I got this error:
Error: The post rest request failed
│   with module.aci.module.aci_mcp[0].aci_rest_managed.mcpInstPol,
│   on .terraform/modules/aci/modules/terraform-aci-mcp/main.tf line 1, in resource "aci_rest_managed" "mcpInstPol":
│    1: resource "aci_rest_managed" "mcpInstPol" {
│ Code: 400 Response: [map[error:map[attributes:map[code:182 text:Password is required for MCP Instance Policy.]]]], err: %!s(<nil>). Please report this issue to the provider developers.
I know that I need a key for MCP configurations, but I don't even configure anything for MCP. I just want it to stay default.
Can someone help me with this issue?
Here is my main.tf:
terraform {
  required_providers {
    aci = {
      source = "CiscoDevNet/aci"
      version = "2.13.2"
provider "aci" {
  username = "admin"
  password = "xxx"
  url      = "https://xx.xx.xx.xx/"
module "aci" {
  source  = "netascode/nac-aci/aci"
  version = "0.8.1"
  yaml_directories = ["data"]
  manage_access_policies    = true
  manage_fabric_policies    = false
  manage_pod_policies       = false
  manage_node_policies      = true
  manage_interface_policies = false
  manage_tenants            = true
 Thanks in advance.
Greets,
Mathias
danischm
I have added an explanation to the GitHub issue here: https://github.com/netascode/terraform-aci-nac-aci/issues/64#issuecomment-2024852152
Hopefully this clarifies the behavior.
mfr-6
hi @matze123
I've got the same issue, I added my 2 cents to the issue already reported, you can see it here: https://github.com/netascode/terraform-aci-nac-aci/issues/64
I'll try to contact the team if no further action is taken since this also blocks me a bit.
The problem is that "defaults" in NAC makes terraform deploy this resource with predefined parameters as shown below:
      mcp:
        admin_state: true
        per_vlan: true
        action: true
        key: cisco
        loop_detection: 3
        initial_delay: 180
        frequency_sec: 2
        frequency_msec: 0
Mateusz Frak NetDevOps | DevNet | Automation DevNet Expert #20240068
Please mark this post as helpful if it solves your issue, to make this visible for other users, thank you!
Hi Mateusz,
thanks for your reply and for the github issue.. hopefully this will solve our problems.
What surprises me a little is that this problem is occurring now and it wasn't 4 weeks ago (before my vacation). With the same code, same versions and the same aci simulator to test the code.
danischm
