Nexus 2K FEX not coming up and interfaces flapping after connecting to Nexus 7K
t844311Imran
I have one nexus 7000 with F2 blade and a new FEX 2248TP.  I have setup all FEX configuration but the communication between 7000 and 2000 is down. The physical connection doesn't work.
We do have the SFP-10GSR available and we already tested on that. I see the interfaces flapping. The issue is only occurring on one new FEX only.
Core# sh int e4/29-30 | i flapped
  Last link flapped 00:00:51
  Last link flapped 00:00:05
  Last link flapped 00:00:01
  Last link flapped 00:00:07
Ethernet4/29 is down (initializing)
Ethernet4/30 is down (Link not connected)
Ethernet3/29 is down (Link not connected)
Ethernet3/30 is down (initializing)
2015 Jul 21 10:38:01.104 Core %ETHPORT-5-IF_DOWN_INITIALIZING: Interface Ethernet3/29 is down (Initializing)
2015 Jul 21 10:38:01.107 Core %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 1 of Fex 199 that is connected with Ethernet3/29 ch
anged its status from Active to Disconnected
2015 Jul 21 10:38:01.272 Core %ETHPORT-5-SPEED: Interface Ethernet4/29, operational speed changed to 10 Gbps
2015 Jul 21 10:38:01.272 Core %ETHPORT-5-IF_DUPLEX: Interface Ethernet4/29, operational duplex mode changed to Full
2015 Jul 21 10:38:01.272 Core %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet4/29, operational Receive Flow Control st
ate changed to off
2015 Jul 21 10:38:01.272 Core %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet4/29, operational Transmit Flow Control s
tate changed to off
2015 Jul 21 10:38:01.294 Core %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 0 of Fex 199 that is connected with Ethernet4/29 ch
anged its status from Configured to Fabric Up
2015 Jul 21 10:38:02.029 Core %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 3 of Fex 199 that is connected with Ethernet4/29 ch
anged its status from Fabric Up to Connecting
2015 Jul 21 10:38:02.055 Core %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 3 of Fex 199 that is connected with Ethernet4/29 ch
anged its status from Connecting to Active
2015 Jul 21 10:38:02.229 Core %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 1 of Fex 199 that is connected with Ethernet3/29 ch
anged its status from Disconnected to Configured
We change the ports on same module and SFPs but the problem is the same. Can you help?
8 Replies 8
Did you bundle these interfaces together?
Can you share the configuration please.
Madhu
N7K# sh run int po199 mem
!Command: show running-config interface port-channel199 membership
!Time: Wed Jul 22 15:47:30 2015
version 6.2(10)
  switchport mode fex-fabric
  fex associate 199
  mtu 9216
interface Ethernet3/29
  fex associate 199
  beacon
  mtu 9216
  channel-group 199
  no shutdown
interface Ethernet4/29
  fex associate 199
  beacon
  mtu 9216
  channel-group 199
    no lacp suspend-individual
  no shutdown
interface Ethernet3/30
  fex associate 199
  beacon
  mtu 9216
  channel-group 199
  no shutdown
interface Ethernet4/30
  fex associate 199
  beacon
  mtu 9216
  channel-group 199
  no shutdown
N7K#
Do you have another fex to check, may be a faulty fex.
Madhu
Or can you reload this fex and check if it resolves it.
Madhu
FEX 158 was the original FEX# which failed and after failures we tried a new FEX# 199 and port-channel# 199.
Did you try changing the uplink ports on parent?
Try to bring up the FEX with only one link in Port-channel and see what happens.
Madhu
Yes I tried changing the pair from 3/23-24, 4/23-24 to 3/29-30, 4/29-30 and tried with one link only also but to no avail. As per TAC, "It sounds like an index pointer is stale or not updated, but it’s not clear where it is exactly. When the links have moved we see them all go down for SDP timeout reasons from the satmgr process, I want to compare the counters against what you just sent in to see if they’re incrementing or not." No response after that from TAC...intriguing indeed.
We replaced the fex twice and verified the SFPs on both sides. We don't want to touch a working production FEX as this FEX has been down for more than 2 weeks now. Management is loosing faith in support. This is a production environment so I can't mess with working stuff. We reloaded the down FEX multiple times already.
I made one interesting observation that even though FEX 158 is nowhere in running config it still shows up in env, not sure why:
N7K# sh environment fex 158
show_env_temperature_fex:1050 mts_send failed, mts_errno=107
show_env_fan_fex:1118 mts_drop failed, mts_errno=107
Power Supply Fex 158:
Voltage: 12 Volts
PS  Model                Power       Power     Status
                         (Watts)     (Amp)
1   --                        --        --     --
2   --                        --        --     --
Mod Model                Power     Power       Power     Power       Status
                         Requested Requested   Allocated Allocated
                         (Watts)   (Amp)       (Watts)   (Amp)
1                         0.00      0.00       0.00      0.00       powered-up
Power Usage Summary:
Power Supply redundancy mode:                 redundant
Total Power Capacity                                0.00 W
Power reserved for Supervisor(s)                    0.00 W
Power currently used by Modules                     0.00 W
Total Power Available                               0.00 W
N7K# sh environment fex 199
ERROR: Fex 199 is not present.
