Nexus 2k integration with 5K
sanjay.sangwan
I used a portchannel between 5K and 2k but after defining the fex interfaces and associating with the port channel , the module is not added to
5K. I restarted the 5K and it adds up.I face the same with the 2nd 2k as well.Is there any other way to avoid the restart.
sanjay
Lucien Avramov
Level 10
Level 10
If you have vPC you need to make the changes on both 5ks.
If it's a single homed 5k, it should happen and no restart is needed. The show fex command takes some time, you can use the show fex # instead.
