Nexus 4001i
Maurice Ball
Level 3
Level 3
I have connected a Nexus 4001i blade switch to two Nexus 5548 switches. I created a vpc from the two Nexus 5548 switches down to a port-channel that I created on the Nexus 4001i on ports e1/15 and e1/16. The Nexus 5548 does not have the layer 3 hardware so it is a layer 2 switch only. I have a Catalyst 3750X connected to the Nexus 5548 and I am using the Catalyst 3750 for all vlan routing. I also had two Nexus 2248 switches connected to the Nexus 5548. I can route traffic fine from the FEX but can not route traffic from the Nexus 4001i. My question is should I be able to route traffic from Nexus 4001i or do I have to have the layer 3 hardware installed in the Nexus 5548 for this to work?
Nexus 4001i config
sh run
version 4.1(2)E1(1f)
feature telnet
feature interface-vlan
feature lacp
feature lldp
vrf context management
  ip route 0.0.0.0/0 172.16.17.1
vlan 1
interface port-channel15
  switchport mode trunk
  switchport trunk native vlan 999
  speed 10000
interface Ethernet1/1
  spanning-tree port type edge
  speed auto
interface Ethernet1/2
  speed auto
interface Ethernet1/3
  speed auto
interface Ethernet1/4
  speed auto
interface Ethernet1/5
  speed auto
interface Ethernet1/6
  speed auto
interface Ethernet1/7
  speed auto
interface Ethernet1/8
  speed auto
interface Ethernet1/9
  speed auto
interface Ethernet1/10
  speed auto
interface Ethernet1/11
  speed auto
interface Ethernet1/12
  speed auto
interface Ethernet1/13
  speed auto
interface Ethernet1/14
  speed auto
interface Ethernet1/15
  speed 10000
  channel-group 15
interface Ethernet1/16
  speed 10000
  channel-group 15
interface Ethernet1/17
  speed 10000
interface Ethernet1/18
  speed 10000
interface Ethernet1/19
  speed 10000
interface Ethernet1/20
  speed 10000
interface mgmt0
  vrf member management
  ip address 172.16.17.15/24
interface mgmt1
cli alias name blade1 telnet 172.16.17.15 vrf management
cli alias name blade2 telnet 172.16.17.16 vrf management
cli alias name core1 telnet 172.16.17.5 vrf management
cli alias name wr copy run startup
cli alias name core2 telnet 172.16.17.6 vrf management
boot kickstart bootflash:/n4000-bk9-kickstart.4.1.2.E1.1f.bin
boot system bootflash:/n4000-bk9.4.1.2.E1.1f.bin
system health loopback frequency 60
N4000.k6.Module7.blade1#
Nexus 5548 config
version 5.2(1)N1(2a)
hostname N5548.k6.Core1
feature telnet
cfs eth distribute
feature hsrp
feature lacp
feature vpc
feature lldp
feature vtp
feature fex
no password strength-check
banner motd #Nexus 5000 Switch
ip domain-lookup
class-map type qos class-fcoe
class-map type queuing class-fcoe
  match qos-group 1
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing class-ip-multicast
  match qos-group 2
class-map type network-qos class-fcoe
  match qos-group 1
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
policy-map type control-plane copp-system-policy-customized
  class copp-system-class-default
    police cir 2048 kbps bc 6400000 bytes
fex 129
  pinning max-links 1
  description "FEX0129"
fex 130
  pinning max-links 1
  description "FEX0130"
vpc domain 1
  role priority 2000
  peer-keepalive destination 172.16.251.2
  delay restore 150
  peer-gateway
port-profile default max-ports 512
interface Vlan1
interface Vlan17
  no shutdown
  ip address 172.16.17.5/24
  description ## Connected Nexus 4001i module 7 PORT e1/15 ##
  speed 10000
  vpc 1
interface port-channel2
  speed 10000
  vpc 2
interface port-channel27
  description ## PORT CHANNEL TO CATALYST 3750 ##
  speed 1000
  vpc 27
interface port-channel29
  description ## Channel Group Fex Fabric 29 ##
  switchport mode fex-fabric
  fex associate 129
  vpc 29
interface port-channel30
  description ## Channel Group Fex Fabric 30 ##
  fex associate 130
  vpc 30
interface port-channel32
  description ## Port-Channel Peer-Link CORE 2 ##
  spanning-tree port type network
  speed 10000
  vpc peer-link
  description ## Nexus 4001i module 7 PORT e1/15 ##
  channel-group 1
  channel-group 2
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
interface Ethernet1/26
interface Ethernet1/27
  description ## CONNECTED TO CATALYST 3750 PORT G1/1/3 ##
  speed 1000
  channel-group 27
interface Ethernet1/28
interface Ethernet1/29
  description ## CONNECT FEX FABRIC 129 ##
  fex associate 129
  channel-group 29
interface Ethernet1/30
  description ## CONNECT FEX FABRIC 130 ##
  fex associate 130
  channel-group 30
interface Ethernet1/31
  description ## VPC UPLINK NEXUS CORE2 ##
  channel-group 32 mode active
interface Ethernet1/32
interface mgmt0
  ip address 172.16.251.1/30
interface Ethernet129/1/1
interface Ethernet129/1/2
interface Ethernet129/1/3
interface Ethernet129/1/4
interface Ethernet129/1/5
interface Ethernet129/1/6
interface Ethernet129/1/7
interface Ethernet129/1/8
interface Ethernet129/1/9
interface Ethernet129/1/10
interface Ethernet129/1/11
interface Ethernet129/1/12
interface Ethernet129/1/13
interface Ethernet129/1/14
interface Ethernet129/1/15
interface Ethernet129/1/16
interface Ethernet129/1/17
interface Ethernet129/1/18
interface Ethernet129/1/19
interface Ethernet129/1/20
interface Ethernet129/1/21
interface Ethernet129/1/22
interface Ethernet129/1/23
interface Ethernet129/1/24
interface Ethernet129/1/25
interface Ethernet129/1/26
interface Ethernet129/1/27
interface Ethernet129/1/28
interface Ethernet129/1/29
interface Ethernet129/1/30
interface Ethernet129/1/31
interface Ethernet129/1/32
interface Ethernet129/1/33
interface Ethernet129/1/34
interface Ethernet129/1/35
interface Ethernet129/1/36
interface Ethernet129/1/37
interface Ethernet129/1/38
interface Ethernet129/1/39
interface Ethernet129/1/40
interface Ethernet129/1/41
interface Ethernet129/1/42
interface Ethernet129/1/43
interface Ethernet129/1/44
interface Ethernet129/1/45
interface Ethernet129/1/46
interface Ethernet129/1/47
interface Ethernet129/1/48
interface Ethernet130/1/1
  switchport access vlan 114
interface Ethernet130/1/2
interface Ethernet130/1/3
interface Ethernet130/1/4
interface Ethernet130/1/5
interface Ethernet130/1/6
interface Ethernet130/1/7
interface Ethernet130/1/8
interface Ethernet130/1/9
interface Ethernet130/1/10
interface Ethernet130/1/11
interface Ethernet130/1/12
interface Ethernet130/1/13
interface Ethernet130/1/14
interface Ethernet130/1/15
interface Ethernet130/1/16
interface Ethernet130/1/17
interface Ethernet130/1/18
interface Ethernet130/1/19
interface Ethernet130/1/20
interface Ethernet130/1/21
interface Ethernet130/1/22
interface Ethernet130/1/23
interface Ethernet130/1/24
interface Ethernet130/1/25
interface Ethernet130/1/26
interface Ethernet130/1/27
interface Ethernet130/1/28
interface Ethernet130/1/29
interface Ethernet130/1/30
interface Ethernet130/1/31
interface Ethernet130/1/32
interface Ethernet130/1/33
interface Ethernet130/1/34
interface Ethernet130/1/35
interface Ethernet130/1/36
interface Ethernet130/1/37
interface Ethernet130/1/38
interface Ethernet130/1/39
interface Ethernet130/1/40
interface Ethernet130/1/41
interface Ethernet130/1/42
interface Ethernet130/1/43
interface Ethernet130/1/44
interface Ethernet130/1/45
interface Ethernet130/1/46
interface Ethernet130/1/47
interface Ethernet130/1/48
cli alias name core2 telnet 172.16.251.2 vrf management
cli alias name core1 telnet 172.16.251.1 vrf management
line console
line vty
boot kickstart bootflash:/n5000-uk9-kickstart.5.2.1.N1.2a.bin
boot system bootflash:/n5000-uk9.5.2.1.N1.2a.bin
ip routing multicast software-replicate
N5548.k6.Core1#
Jayakrishna Mada
Hi Maurice,
Are you trying a ping using default vrf or management vrf i mean
ping x.x.x.x or ping x.x.x.x vrf management
if you are just doing ping x.x.x.x its not going to work since there are no IP defined in default vrf context.
If you are trying ping x.x.x.x vrf management then are you able to ping the default gateway, 172.16.17.1 ? if yes see if you have proper routing configured on the L3 router that is your CAT3750.
Hope this helps.
Thank
JayaKrishna
Jayakrishna Mada
Hi Maurice,
Hope this helps.
Thank
JayaKrishna
ok, thanks for the help
