Nexus 5000 NXOS downgrade
stebyrne
I need to downgrade a Nexus 5548UP from 5.1.3 to 5.0.3.
When performing the incompatibility check, it fails on the running config saying SCP--SERVER is enabled - strict failure.
I haven't got this feature specified and it doesn't show up on a show feature command. The recommended course of action is 'no feature scp-server' which is an invalid command
Does anyone know a way around this?
8 Replies 8
vdsudame
can you paste the command alongwith the exact output as well as attach 'show run' from the switch ?
Vin.
can't paste config but :
xxxxxxx# sh incompatibility system bootflash:n5000-uk9.5.0.3.N1.1c.bin
The following configurations on active are incompatible with  the system image
1) Service : securityd , Capability : CAP_FEATURE_SECURITY_SCP_SERVER
Description : SCP Server is enabled.
Capability requirement : STRICT
Disable command : no feature scp-server
xxxxxxxxx# sh feature
Feature Name          Instance  State
Flexlink              1         disabled
amt                   1         disabled
bgp                   1         disabled
cts                   1         disabled
dhcp                  1         disabled
dot1x                 1         disabled
eigrp                 1         disabled
eigrp                 2         disabled
eigrp                 3         disabled
eigrp                 4         disabled
eth_port_sec          1         disabled
fcoe                  1         disabled
fcoe-npv              1         disabled
fex                   1         enabled
glbp                  1         disabled
hsrp_engine           1         disabled
http-server           1         disabled
interface-vlan        1         enabled
lacp                  1         enabled
ldap                  1         disabled
lldp                  1         enabled
msdp                  1         disabled
ospf                  1         disabled
ospf                  2         disabled
ospf                  3         disabled
ospf                  4         disabled
pim                   1         disabled
poe                   1         disabled
private-vlan          1         disabled
privilege             1         disabled
ptp                   1         disabled
rip                   1         disabled
rip                   2         disabled
rip                   3         disabled
rip                   4         disabled
sshServer             1         enabled
tacacs                1         enabled
telnetServer          1         disabled
udld                  1         enabled
vem                   1         disabled
vmfex                 1         disabled
vpc                   1         enabled
vrrp                  1         disabled
vtp                   1         disabled
xxxxxxxxx(config)# no feature scp-server
% Invalid command at '^' marker.
xxxxxxxxx(config)#
We are investigating this further.. sounds buggy in nature ...I am trying to reproduce on my switch but cant so far, I assume you ran the command, show install all impact system bootflash:n5000-uk9.5.0.3.N1.1c.bin kickstart bootflash:n5000-uk9-kickstart.5.0.3.N1.1c.bin and it gives you a reason for not being able to downgrade because of this compatibility, correct? if you want to downgrade, for now you can change the boot variables to point to the old image, save config and reload. we dont prefer downgrading this way, but thats the only option ...
Vin.
Hi Vin,
you're correct, we had the following returned:
xxxxxxxxxxxxxx# show install all impact kickstart bootflash:n5000-uk9-kickstart.5.0.3.N1.1c.bin system bootflash:n5000-uk9.5.0.3.N1.1c.bin
Verifying image bootflash:/n5000-uk9-kickstart.5.0.3.N1.1c.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.5.0.3.N1.1c.bin for boot variable "system".
Verifying image type.
[###########         ]  50%
Extracting "system" version from image bootflash:/n5000-uk9.5.0.3.N1.1c.bin.
Extracting "kickstart" version from image bootflash:/n5000-uk9-kickstart.5.0.3.N1.1c.bin.
Extracting "bios" version from image bootflash:/n5000-uk9.5.0.3.N1.1c.bin.
Extracting "fexth" version from image bootflash:/n5000-uk9.5.0.3.N1.1c.bin.
"Running-config contains configuration that is incompatible with the new image (strict incompatibility).
Please run 'show incompatibility system ' command to find out which feature needs to be disabled.".
[#                   ]   0% -- FAIL. Return code 0x40930029 (Current running-config is not supported by new image).
Pre-Upgrade check failed. Return code 0x40930029 (Current running-config is not supported by new image).
Stephen, can you please open a TAC Case on this? Let me know when you open one. We would like to get some more logs from the switch ?
Vinayak.
Hi Vinayak,
the company I'm working for has raised a TAC Case already, that is being investigated.
I don't know the reference, sorry.
if you can find out the tac case no and give it to me, that would be great. - Vin.
