Nexus 5000 SNMP traps for failed FEX PSU's
ametcalf
If entity traps are enabled, will the failure of a PSU in a FEX (with 2 PSU's) result in a trap being sent or are the entity traps only for the 5000 rather than the 2000.
Reason for asking:I have a number of failed PSU's in FEX's which might have been a failed since power on and therefore have never transitioned from working to failing to send a trap. The FEX itself is constantly complaining of voltage issues
08/02/2013 04:52:41.572800: Err:over volt fault occured for ps:1
08/02/2013 04:52:41.572839: Err:stat=2048
08/02/2013 04:52:41.572853: Err:over-output-current fault occured ps:1
08/02/2013 04:53:14.936602: Err:over volt fault occured for ps:1
08/02/2013 04:53:14.936645: Err:stat=2048
08/02/2013 04:53:14.936658: Err:over-output-current fault occured ps:1
08/02/2013 04:53:30.46732: satctrl_alive_hdlr: alive_count is 23001700
Power Supply Fex 103:
Voltage: 12 Volts
PS  Model                Power       Power     Status
                         (Watts)     (Amp)
1   --                        --        --     fail/shutdown
2   N2200-PAC-400W        396.00     33.00     ok
Thanks Andy Metcalf
padramas
Hello Andy,
Do you receive SNMP traps for other events ? any special config like SNMPv3 / authentication etc ?
I have not tested in lab. Is it possible for you to check " cefcFRUPowerStatusEntry "   /  1.3.6.1.4.1.9.9.117.1.1.2.1.2.471  OID ?
or do snmp walk for  1.3.6.1.4.1.9.9.117.1.1.2.1 ?
Padma
Padma,
     Thanks for your response, we do get snmp traps from these switches, I tested that with a "test pfm snmp test-trap powersupply" and the trap was received, There is no special snmp configuration. The OID you are requesting returns a different value for each of our two 5010 switches
switch A= SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.3.471 = INTEGER: 1087
switch B= SNMPv2-SMI::enterprises.9.9.117.1.1.2.1.3.471 = INTEGER: 1018
In both switches entity traps are enabled
entity               : entity_mib_change                            Yes
entity               : entity_module_status_change                  Yes
entity               : entity_power_status_change                   Yes
entity               : entity_module_inserted                       Yes
entity               : entity_module_removed                        Yes
entity               : entity_unrecognised_module                   Yes
entity               : entity_fan_status_change                     Yes
entity               : entity_power_out_change                      Yes
I notice your OID references "FRU" and I see a hidden extension to the snmp-server enable trap command
hidden-nameB(config)# snmp-server enable trap entity ?
  entity_fan_status_change     Entity Fan Status Change
  entity_mib_change            Entity MIB change
  entity_module_inserted       Entity Module Inserted
  entity_module_removed        Entity Module Removed
  entity_module_status_change  Entity Module Status Change
  entity_power_out_change      Entity Power Out Change
  entity_power_status_change   Entity Power Status Change
  entity_unrecognised_module   Entity Unrecognised Module
hidden-nameB(config)# snmp-server enable trap entity fru
I would be interested to see if this FRU was required yet hidden.
SW version  system:    version 5.0(3)N2(2)
  5.1(3) does not have the fru command option.  The command is snmp_server enable traps entity entity_power_status_change.
  I don't believe this is turned on by default, but I cannot find any documentation that says this command is not enabled by default with the snmp-server enable traps command.
  I also do not see any documentation that states this command will notify us of a Nexus 2000 power supply failure.  Please advise.
