Nexus 5548 sjowing Fatal error
HCL Support
We have Cisco Nexus N5K-C5548UP-FA and this is showing the Fatal error details below,
Power-On Self Test fatal error: PCIe error
blogger: /var/log/isan.log: No such file or directory (2).
Starting Nexus Oxygen Platform POST.....
Executing Mod 1 1 SEEPROM Test:...done (0 seconds)
Executing Mod 1 1 GigE Port Test:.Cannot get driver information: No such device
Fail to parse /post/ethtool.log PASS/FAIL result
ERROR: Executing 5 on dev 0
ERROR: Executing 5 on dev 1
ERROR: Executing 5 on dev 2
ERROR: Executing 5 on dev 3
done (0 seconds)
Executing Mod 1 1 PCIE Test:.
## Failed: PCI device - Intel 82575EB Gigabit Ethernet Controller
Also attaching the console logs coming after powering ON.
Suggest me if this is the Hardware failure of Nexus Switch.....
Ashutosh
(bus:02, dev:00, func:00, vendId:8086, devId:10A7)
(bus:02, dev:00, func:01, vendId:8086, devId:10A7)
(bus:03, dev:00, func:00, vendId:8086, devId:10A7)
(bus:03, dev:00, func:01, vendId:8086, devId:10A7)
## Info : Based on P0 board detection.
ERROR: Executing 12 on dev 0
ERROR: Executing 12 on dev 1
ERROR: Executing 12 on dev 2
ERROR: Executing 12 on dev 3
.............done (0 seconds)
Mod 1 1 Post Failed
POST is completed
autoneg unmodified, ignoring
Oleksandr Nesterov
Hi Guys
I would suggest you to replace the device as it seems there is an issue with hardwre.
HTH,
Alex
Jay UCS
Hi, did you ever figure out what was the problem and solution ? Thanks !!
dens
Have same problem. anyone find any solution?
oader> boot ucs-6100-k9-kickstart.5.0.3.N2.4.13l.bin
Booting kickstart image: ucs-6100-k9-kickstart.5.0.3.N2.4.13l.bin....
..............................................................Image verificatio
n OK
ÿUsage: init 0123456SsQqAaBbCcUu
INIT: [ 11.928189] I2C - Mezz absent
Starting system POST.....
Executing Mod 1 1 GigE Port Test:....done (32 seconds)
## Failed: PCI device - Carmel ASIC - Nuova Switch Multi-function Traffic Port ASIC - car1
(bus:11, dev:00, func:00, vendId:1137, devId:004D)
## Failed: PCI device - Carmel ASIC - Nuova Switch Multi-function Traffic Port ASIC - car2
(bus:13, dev:00, func:00, vendId:1137, devId:004D)
ERROR: Executing 12 on dev 8
ERROR: Executing 12 on dev 9
Mod 1 1 Post Failed
POST is completed
can't create lock file /var/lock/mtab~208: No such file or directory (use -n flag to override)
S10mount-ramfs.supnuovaca Mounting /isan 3000m
Mounted /isan
Creating /callhome..
Mounting /callhome..
Creating /callhome done.
Callhome spool file system init done.
nohup: redirecting stderr to stdout
