05-12-2014 01:38 AM - edited 03-01-2019 07:34 AM
Hi.I'm hanoh.cha
N5K temperature was increased after, shutdown it.
Temperature is over 40 degrees during 2 min before switch shutdown.
Do you know about n5K temperature threshold value change?
thank you.
06-20-2014 02:52 PM
Hello Hanoh,
Temperature sensor health monitoring diagnostics are referenced for the 5548 here with very little detail:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/system_management/502_n1_1/Cisco_n5k_system_mgmt_cg_rel_502_n1_1.pdf
Show environment does give temperature information, so it could be scripted to be retrieved, however SNMP is more desirable
Hope it would helps you,once got answer please make it answered.
Gaurav
Log in to Community
