05-22-2012 11:32 PM - edited 03-01-2019 07:06 AM
Fex does not work with following configuration. Can Cause?
fex 104
pinning max-links 1
description "FEX0104"
interface port-channel104
switchport mode fex-fabric
vpc 104
fex associate 104
interface Ethernet1/41
fex associate 104
channel-group 104
interface Ethernet1/42
fex associate 104
channel-group 104
N5K-21# sh int status
Port Name Status Vlan Duplex Speed Type
Eth1/41 -- SDP timed 1 full 10G 1/10g
Eth1/42 -- SDP timed 1 full 10G 1/10g
N5K-21# sh int eth1/41 transceiver
Ethernet1/41
transceiver is present
type is Fabric Extender Transceiver
name is CISCO-FINISAR
part number is FTLX8570D3BCL-C1
revision is A
serial number is xxxxx
nominal bitrate is 10300 MBit/sec
Link length supported for 50/125um fiber is 20 m
Link length supported for 50/125um fiber is 100 m
Link length supported for 62.5/125um fiber is 10 m
cisco id is --
cisco extended id number is 4
N5K-21# sh int eth1/42 transceiver
Ethernet1/42
revision is A
cisco id is --
N5K-21#
N5K-21# sh int fex-fabric
Fabric Fabric Fex FEX
Fex Port Port State Uplink Model Serial
104 Eth1/41 Fabric Up 0
104 Eth1/42 Fabric Up 0
05-23-2012 04:25 AM
Remove the vPC statement under your FEX-Portchannel:
no vpc 104
shut
no shut
Marcel
